Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Stroker HP Estimate and build
Old 02-26-2013, 11:17 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
Originally Posted by vinniekq2 View Post
what sarcasm?
I use a 950 on my engine.a 650 cant move enough air with a standard type camshaft to make much over 425 HP.
That cam you picked sounds like a 57-6,000 RPM cam,depending on ICL and LDA?
My car also uses an open plenum intake,I like mid range power more than off idle,different from that other fellas.
I too use a 5 speed,,,
I like the video....Sounds really good...
I was kidding about the sarcasm. But i guess your probably right about the air movement. The heads that I am getting also offer a port job for a couple extra dollars. So it would make sense to get a bigger carb...
What type of 5 speed are you using? I am looking for options and best case scenario. The car is a 72 chevelle...
Thanks,
