Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Stroker HP Estimate and build
Old 02-26-2013, 11:34 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
I bought a brand new TKO 600. I ordered the .82 over drive. If you drag race,you might want the .68 overdrive depending on the rear axle ratio you use.The TKO/scattershield/shifter came to 3k. I also bought a lighter sfi approved steel flywheel.I use a diaphragm style clutch.
