383 Stroker HP Estimate and build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-26-2013, 11:36 PM
deckofficer's Avatar
www.tbuckets.lefora.com/
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
Originally Posted by vinniekq2 View Post
My car also uses an open plenum intake,I like mid range power more than off idle,different from that other fellas.
I too use a 5 speed,,,
I run the Tremec TKO 600 also, with the 0.64 OD 5th.
Well I've joined you as of today. I really like good off idle performance but missed the high rpm zing of a conventional high performance build. Today drove the Track-T for about 40 miles with its new engine, a Dart block sbc 427. Dyno's at 526 HP @ 5700 and 556 lb/ft @ 4400. Because the intake is taller I will have to massage the hood to get it back on.
  #17 (permalink)
Old 02-26-2013, 11:47 PM
vinniekq2's Avatar
scott offers a very nice engine combo.My friend in Calgary bought a 540 from Scott.
  #18 (permalink)
Old 02-26-2013, 11:55 PM
Wiki Edits: 12
Though I'm in California, that was why I bought from Scott too. Many stories of his race engines going season after season untouched. That is uncommon for the flogging a race engine receives. I figure if his race engines are that tough, then his street engines ought to be pretty good too. Plus he is able to produce big HP at just 5700 and gobs of torque at 4400. I only have those 40 miles of experience, but in my light weight ride it scoots.
  #19 (permalink)
Old 02-27-2013, 12:10 AM
vinniekq2's Avatar
My 434 is 10 years old,John so John 540(race car motor) is 12 years old.John freshened his engine once.My engine is not from Scott.I got my parts and machine work from Jeff Lukovich.Similar valve covers
  #20 (permalink)
Old 02-27-2013, 12:13 AM
Wiki Edits: 12
He does have a good rep.
  #21 (permalink)
Old 02-27-2013, 12:22 AM
vinniekq2's Avatar
deckofficer has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
that little red car? Im guessing taction is a problem.should run low 11z
  #22 (permalink)
Old 02-27-2013, 12:35 AM
68NovaSS's Avatar
Wiki Edits: 9
You have two threads about this same motor, they've been merged here.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
  #23 (permalink)
Old 02-27-2013, 02:22 AM
Wiki Edits: 12
The lighter the car, the less tire spin and more hook and book. Ran Sacramento Raceway with the 355 which had 386 HP, 10.8 @ 132. I would say the 526 HP 427 would be at least a second faster. Weight makes such a big difference for going fast, cornering, and stopping. For over 40 years I had hot rods in the 3500~4200 lb range and now I've decided not to fight The Laws of Physics, going with 1790 lbs. Had I done this 40 years ago, their would have been a lot less hot rods in my garage over the years.
Try light weight, you'll like it. Carroll Shelby had it right.
One of my heavyweights about 25 years ago, and before my beard turned gray.
  #24 (permalink)
Old 02-27-2013, 09:22 AM
vinniekq2's Avatar
what you said I 100% agree with.Thats why so many people with their 383s have no chance against all the kids with Civics with V-teca. The import guys all have 200 hp or more in 2300 pound cars. Then match that against even a 400 hp 383 and watch the imports dart to 60 MPH leaving the big V-8s spinnin their wheels
  #25 (permalink)
Old 02-27-2013, 09:46 AM
Wiki Edits: 12
At that my friend is why I cover things up. First, the Asian Tuner set has no idea I'm lighter than them, and with my narrow engine cover and exhaust tucked up underneath my ride, they assume I'm a 4 cylinder too. Notice the bulge in the side cover for clearance of the Ram's Horn exhaust.
  #26 (permalink)
Old 02-27-2013, 10:01 AM
vinniekq2's Avatar
You would have to be deaf to think that is a 4 banger,lol.Did you get the hydraulic cam or solid option?How does that car at 175 mph?
  #27 (permalink)
Old 02-27-2013, 10:15 AM
Wiki Edits: 12
Hydraulic roller. I meant when at car shows with the engine not running you always here spectators comment to each other "Must be a Pinto 2.3 L 4 banger". When the engine is running the cat is out of the bag.
I only took it up to 125 on yesterday's short test drive.
need help with 383 stroker build marvinp84 Engine 40 03-03-2013 09:53 AM
estimate hp on 383 build sheltonk7 Hotrodding Basics 2 01-20-2009 11:46 AM
How do I build a 383 stroker? KFXrider88 Engine 2 06-16-2006 12:10 PM
How to build a 383 stroker JAKE 68 GMC Engine 15 05-30-2006 01:28 PM
build a 383 stroker jo5hi3 Engine 4 11-20-2003 12:07 AM
