Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker kit (Ebay)
Old 04-20-2005, 02:30 AM
ChevyThunder ChevyThunder is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 51
Well it all depends on what you want to do as far as power and such. I mean for a basic daily driver cast crank and I beam rods are fine. The other thing is depending on what compression you are running, with cam lift, rocker arm ratio and such you may want to be able to make sure your your pistons have the proper valve recess. Of course for your average rebuild these things aren't much of a problem, but I'm guessing since you are looking at doing a 383 you aren't just wanting a normal rebuilt 350.
BiG WHiskey
