Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Stroker Kits
Old 11-24-2004, 12:22 PM
tornado-tech's Avatar
tornado-tech tornado-tech is offline
Either Scat or Eagle both make good rotating assemblies with the Scat being a little cheaper. You will need the stroker crank designed for the one-piece seal that your block has. You will also have to block machined for the extra side clearance that the 3.75 stroke needs. Also check rod to cam clearance with the 5.7 rods. With the vortec heads on top of a late-model hydraulic-roller block, you will have an excellent combination. Check out Speedway Motors in Lincoln since you live in Nebraska.
