383 stroker kits?? for a 98 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 06:35 AM
ok i have 1998 350 votrec head motor i am wanting to build a stroker... what are some steps i need to folow nd were is the best place to get a kit thank you for the help
Old 01-18-2011, 07:16 AM
Scat and Eagle make kits, problem is most kits come with a -12CC dish leaves you 10.3:1.. i am building the same engine right now. its a 97' block
Techinspector likes the -18CC Keith Black pistons as they give a D shaped chamber for better flame travel and less detonation. They come with some Eagle kits but you need to search. I would have used them but I was having a hard time finding a shop that was willing to sell them and had them in stock.
Heres the Run Down,
Scat Crank Cast steel
Pro Comp 5.7 Rod
-22CC Probe Pistons Forged
8" Balancer
Flexplate
Custom Balanced With Sheet
Hastings Rings
King Bearings
Cost 865 to my Door
The setup took minimal Clearancing on the Main web I am running a .501 .509 Roller Cam with GM hydraulic roller lifters
Cut the block .010 Leaves me 9.35:1 ish depending on my Head Gasket and it will run on Pump Gas
1005.00 Got me .015 Head Gaskets, Cam bearings, Oil pump Kit, and head bolts, and soft plugs.
another 365 and I have my cam new rollers, and Timing set by Cloyes.
If you are interested I can give you there number PM me
Old 01-18-2011, 10:22 AM
anyone else have any input ons good kit to help produce 500HP plan on using trick flow super 23 215 heads with the 2.08-1.60 valves or think those are to much... i am wanting to run 93 octane pump gas
Old 01-18-2011, 10:47 AM
Problem is you run into expensive limits. The scat and eagle cranks are rated to 500HP meaning you are at your limit.
What you need to answer is what are you planning to use this for?
What kind of budget are you in?
What type of RPM will this see?
Old 01-18-2011, 10:53 AM
Banned
I wouldn't worry too much about that Scat crank, just keep the RPM under 7,000 and pay real close attention to machining, balance, and assembly.
Old 01-18-2011, 11:23 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
To make the most of those trick flows and get your 500HP you may be in the 550lift area and allot of duration, you could most likely go with forged probe 12cc dish pistons cause you will want the higher compression to light it off IMO
A healthy cam, alumimum heads and good quench will help it live with 10.3-10.5 compression and 93 octane if the convertor and gears are matched up and the tune is bang on.
this kit uses scat crank and probe pistons, they may be able to substitute the flat tops for the dish version, good folks to deal with.
http://skipwhiteperformance.com/deta...x?Item=383-ROT
Old 01-18-2011, 11:35 AM
thats what I have. I subbed for a deeper dish piston to run easy on pump gas and get me around 9.3:1 SCR, depending on the head mill.
Old 01-18-2011, 02:08 PM
CJ_1080's Avatar
known to do dumb stuff!!
I just got done breaking in my1996 383. I used SRP sportsman 16cc D dish and polished up the combustion chambers. After all was shiny and deshrouded, the combustion chambers were all between 67-68 cc's. I used. 028 headgaskets. 6 inch cap screw rods. Minimal grinding on the block when using capscrew rods!
stroker kits??? boatanchors Engine 4 09-30-2008 12:35 AM
302 stroker kits cliff tate Engine 1 09-26-2005 06:47 PM
383 Stroker Kits Chevy21 Engine 11 12-02-2004 10:38 AM
Big Chevy Stroker kits astroracer Engine 1 12-21-2003 01:28 PM
Stroker Kits Jeff69cat Engine 7 10-18-2002 10:39 AM
