383 stroker oil leak. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 08:00 PM
86 and up stroker has an oil leak on passenger side only under acceleration. change intake gaskets, pan gasket, valve cover gaskets twice, dip stick tube sealed. Turn left and give power and is worse and smokes bad. starter is wet headers wet and stained. can't figure it out. exstremely frustrated. Rear main leaking a little. new pcv, tried it all I think. HELP TJ
Old 09-11-2011, 08:20 PM
Does the right side have a bolt in the front holes motor mount in the frt of block,I think the upper hole has a passage to the fuel pump push rod and will spray oil with rpm.
383 stroker - intake oil leak - HELP! transamgta383 Engine 16 08-16-2011 12:52 PM
388 stroker oil leak dgmalibu10 Engine 2 07-23-2010 07:46 PM
383 Stroker Oil Leak butch383 Introduce Yourself 5 07-22-2010 10:04 PM
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 11:16 AM
Ford power steering box leak (steady leak) StevenC Suspension - Brakes - Steering 7 06-17-2005 09:36 AM
