383 stroker question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 11:38 AM
i was recently searching for 383 stroker combos on the net and i read that a 9:1-9:5 383 stroker with vortec heads and compcams XE274H cam is a popular combo. Is anyone running this combo? or one similar to it? And if so, i'm curious to find out what kind of hp and torque #'s did you get with this combo??? thanks a lot!
Old 09-18-2006, 12:13 PM
Very few people would actually dyno a mild setup like that, and actual results can very widely. You could probably find something similar to your setup at Ryans Car Pages and go from there.
http://www.ryanscarpage.50megs.com/combos1.html
Old 09-18-2006, 12:47 PM
firestone's Avatar
http://teamrfc.gospelcom.net
This is not exactly the same motor, but I think it would give you a fairly close comparason. The main difference is that they use a hyd roller cam instead of a hyd flat tappet. The cam that they used has the following specs (230 236 @.050 .540 .550 lift with 1.6 rockers) The xe274h would be 230 236 @ .050 .520 .520 with 1.6 rockers). The vortec heads drop off in flow after ~.500 lift, so the extra lift with the roller in this case may not have as much of an effect as usuall. Usually, in a motor like this, you an assume a ~20 hp gain with a roller over a flat tappet given the same duration at .050 but that is a really rough estimate. I think you could subtract around 20 hp from the motor below and have a rough idea of the power it would make.
Here is the 383 I was talking about. 449 hp @ 5300 RPM 483 ft lbs @ 4600 RPM.
http://www.chevyhiperformance.com/te...ht_383_engine/
Here is a 406 with the vortec heads and the a lunati cam almost identical to the xe274h. I think you would be looking at similar max hp (mainly due to having 1.6 rockers), but not as much low end torque. 428 hp @ 5100 rpm 535 ft lbs @3500 RPM.
http://www.chevyhiperformance.com/te..._block_torque/
Adam
Old 09-18-2006, 01:01 PM
thanks guys these articles were really helpful!
383 stroker turbo questions work_n_progress Engine 10 06-23-2011 09:55 PM
hp of a 383 stroker mathjew Hotrodding Basics 5 11-02-2004 10:14 PM
Do I need to have my 383 stroker rebalanced if I replace the balancer? Rodrunner Engine 1 07-03-2003 05:15 AM
Legit 383 stroker? thiems Engine 1 05-15-2003 03:30 PM
