383 stroker questions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-06-2012, 11:10 AM
I have block and heads but I still maybe buying heads . I am looking at cast scat crank forged rods and flat tops. That said that said is about 900 bucks
  #17 (permalink)
Old 08-06-2012, 11:28 AM
vinniekq2's Avatar
what heads do you own?have they been flow tested?what block?
machine work and balancing of a race engine can go as high as $800.oo,,,$250 oo for gaskets and timing chain. that leaves 2k for rotating parts,,, buy a used intake,,good carbs are $600.oo,,,fill in the blanks from here, Good camshaft and kit 375?
  #18 (permalink)
Old 08-06-2012, 11:39 AM
Banned
You can get 450hp out of a 350 on 87 octane... so why bother with a 383 and 110 octane? Seems like a lot of wasted money and effort.
  #19 (permalink)
Old 08-06-2012, 11:43 AM
I have a set of original double humps, old technology so like I said probably be buying heads also
  #20 (permalink)
Old 08-06-2012, 11:45 AM
vinniekq2's Avatar
double hump what? 194s or 202s? screw in studs or pressed? list all your parts please
  #21 (permalink)
vinniekq2's Avatar
PS what kind of car and what size headers are you using?
  #22 (permalink)
Old 08-06-2012, 11:52 AM
1.94 pressed studs , most likely a late eighties mustang thank you all once again headers I have not decided on yet as I need to concentrate on getting the motor together first
  #23 (permalink)
Old 08-06-2012, 11:57 AM
Banned
You can get these rebuilt and ported to meet your goals for less than a grand... or buy some chinese aluminum heads that will more easily meet your goal for $750. Or buy some bad *** darts or afr's or profilers for a little under 2 grand...
For 450hp id get a good used 4 bolt short block, hone and rering it, get procomp 210cc heads with 58cc chambers, a hurricane intake, a good solid flat tappet cam in the 240's range, 1 5/8" long tube headers, and a rebuilt carb (750 or bigger). if you're careful you'll have 450hp on 87 octane for less than $1750...
If you want more put a 100hp shot of nitrous on it.
  #24 (permalink)
Old 08-06-2012, 11:58 AM
vinniekq2's Avatar
I spent 3k on headers and exhaust. You need to plan the whole trip before you start or it will cost a lot more when you redo things.
You want 450 ish HP? from what? a smal engine or big engine. I used a big small block because I have a vette and wanted a small block. also weigh was my concern,not that my car handles well,I didnt want to make it worse. Whats the market like where you are,maybe find a used engine in your area and rebuild/freshen that? HP is expensive,I spent over 10k on my engine and put it in a 5k car,now my car is worth 5k.I spent more than 10k on other parts to live behind my engine,,, where are you taking your project?
  #25 (permalink)
Old 08-06-2012, 12:08 PM
Originally Posted by vinniekq2 View Post
re imsport,,Each point of compression is about 10% more peak horsepower and an increase in torque at every RPM.
I bet that new Mazda engine that has 14:1 CR is a rocket then????
Might be, if it was built as a racing piece. I have done actual dyno testing of various engines for racing purposes but have done very little for optomized street use where efficiency and driveability are more important.
  #26 (permalink)
Old 08-06-2012, 12:12 PM
I am just looking to build a solid7.5 second eighth mile car, I honestly don't believe I can accomplish this without a set of dart or far heads. Ad you said I'm not the most planned at this point as i am still searching around, I have a fresh short block already I just wanted to build a stroker out of it.
  #27 (permalink)
Old 08-06-2012, 12:15 PM
vinniekq2's Avatar
If its race only then stick that Fresh shortblock in with a big cam and steep gears and race that until you decide what you want or it explodes
  #28 (permalink)
Old 08-06-2012, 12:21 PM
I am just gonna go with my gut build a nice 6" 383, if it takes me longer to do so be it, I will just have to expand my budget and take my time. After its all said and done I'll have a nice play toy thank you all
  #29 (permalink)
Old 08-06-2012, 01:00 PM
Banned
There's nothing wrong with spending more to accomplish the same goal, a lot of people do it.
I'm just used to doing the same thing for less. I can't afford labels, and even if I could I wouldn't buy into it, but I go to the shows and there's a lot of slow guys proudly discussing how much they have in their cars and I guess for some it stands as a testament to their comittment.
I still prefer the guys who hit 10's for less than some people spend on their trailer they use to haul their show queens.
Then there's those who have both intellegence and money and have garage built cars running 9's... those are the guys everyone envys.
  #30 (permalink)
Old 08-06-2012, 01:20 PM
I agree whole heartedly with you but you know what's another thousand bucks when it's something you want I just don't need any catastrophic failure, and I like to use good brand items I agree I could do it cheaper also. You were all a bunch of help and I appreciate it
questions about a 383 stroker gamedawg03 Engine 0 02-29-2012 04:21 PM
383 stroker turbo questions work_n_progress Engine 10 06-23-2011 09:55 PM
stroker 383 mopar questions hotrodsather Engine 5 02-12-2009 12:42 PM
383 Stroker setup questions speedingpenguin Engine 22 08-08-2006 12:29 PM
383 Stroker questions Pre-StrokerC1500 Engine 9 05-23-2006 01:53 PM
