383 Stroker Rotating Assembly questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2009, 09:58 AM
Folks, I'm preparing to build a Chevy 383 stroker which will live on the street in a pickup truck and I have a couple questions about the rotating assembly.
First, let me say that I'm building the engine pretty much from scratch. So far I have a 2007 marine 350 which I hope will donate the vortec heads, manifold, 4-barrel, ignition system, maybe rods, pushrods, some small parts. I can't see using the block 'cause I think it's been run in salt water and I know better than to trust it after that. But I also have a good 4-bolt 2-piece rear main seal block. So I'm thinking about the rotating assembly for now.
Assuming I use my standard rods, can I use an internal-balance crank if I choose the right pistons? If yes, is there any advantage to doing this? Is the external-balance crank just as good and any less expensive? I'm not stuck on using the rods I have, but would like to if possible 'cause I want to hold costs down. I don't have any flywheel or balancer yet.
Old 11-05-2009, 03:23 PM
BOBCRMAN@aol.com's Avatar
On the street in a pickup= Use the external balance cast crank. These babies can handle 500+ hp. Use a 400 balancer and flywheel/flexplate. These aftermkt cranks have to be balanced. I sell/build lots of em..
383 Stroker crank-rods-pistons questions darefugee Engine 17 05-11-2014 04:50 AM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
383 stroker purchase comparison kfrom76 Engine 3 10-26-2009 02:42 PM
383 head and rotating assemblie help 56chev100 Engine 4 08-19-2009 10:06 AM
383 stroker built...now need cam suggestions Astrodokk Engine 7 01-31-2009 02:53 PM
