383 stroker seized - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 07:53 AM
383 stroker seized
I have a 1981 El Camino with a mild 383. I have been having issues with the carb (600cfm Holly) perculating and the engine makes a ticking sound when accelerating or under load. Well the other day i was driving down the road about 55mph and running about 2500RPM and 160 degrees. I also just filled it up with 100 octane, i know that was a mistake. The engine started making a slapping sound so i shut it off immediatly and pull to the side of the road to check things out. After a few minutes of looking around i get back in the car, turn the key, and the engine would not turn over. What would cause it to lock up like that?
Old 11-29-2012, 08:45 AM
Banned
no water.. or oil
Old 11-29-2012, 08:49 AM
383 stroker seized
Well one reason if the gas was perculating. After you shut it down the gas drains out of the carburetor into the intake manifold then down into the cylinders. This washes all the oil from the cylinder walls into the oil pan. Dry starts not good for pistons and rings. Gas mixing with the oil is not good either. You might want to pull the spark plugs and squirt some motor oil mixed with some Marvel Mystery Oil into the cylinders and let it sit. Maybe the next day you can try turning the engine over with a breaker bar and socket. Jegs, Edelbrock, Mr. Gasket, Holley all make a heat shield that goes under the carburetor. Sounds like the engine has to come out to be taken apart to see what exactly happened.
Old 11-29-2012, 12:21 PM
hcompton's Avatar
Old & Furious
It very well could be hydro locked dont force it to turn over. Take the plugs pit and see if you can turn it over with all the plugs out.
Was it dead locked or is your starter crapping out. Its not uncommon for a car with starter issues to not turn over hot. Gm starter or mini gear starter?
Old 11-29-2012, 12:52 PM
vinniekq2's Avatar
like mentioned,turn the engine over with the plugs out.If the starter doesnt work,try a breaker bar.If it does not turn over with the bar,oops. seized maybe.Ive had it happen,chaned the starter,boosted the battery then went back to step 1,,,,
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 09:16 AM
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 12:12 PM
383 Stroker StrokerBoy383 Engine 6 04-10-2008 08:41 PM
383 stroker +nub+ Engine 2 10-02-2003 08:19 AM
383 stroker Turbostan231 Engine 8 02-19-2003 10:13 AM
