383 stroker setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2012, 11:04 PM
383 stroker setup
Yes i have aquired a 350 bored .30 over cut for a 400 crank. The the crank is a eagle crank internally balanced with 5.7 i-beam rods forged eagles. Im going with 10.5 compression forged pistons from summit. Im going with alluminum 2.08 valves to boost up the compession to 11.5 to 1. Im trying to get 600hp on motor. I need some advice to get that kind of hp....its going in a 86 z28. I have a 700r4 wiyh a 3200 stall....
Old 06-05-2012, 11:14 PM
68NovaSS's Avatar
Wiki Edits: 9
You have a .030 over 350 cut for a 400 crank?
And you're going with aluminum 2.08 valves to up the compression to 11.5:1?
So basically you're looking at building a 383 SBC with 600 hp? Assume it's just a street car...what's your budget?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 06-05-2012, 11:18 PM
Well my budget is 300 to 400$ a week. Buying parts week by week. I jus need help finding the right cam, heads, nd intake.....will the eagle i-beam 5.7 rods handle the 600hp
Old 06-06-2012, 12:40 AM
are you planning on racing the car or is it mainly going to be a street drivin car or streey/strip 60/40 per say
Old 06-06-2012, 12:46 AM
Street/strip. Lik a weekend car basically
Old 06-06-2012, 04:12 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
What has been done to the transmission, drive shaft, rearend, tires, and suspension to be able to hold 600hp? You normally don't change valve sizes to change your compression values.
Old 06-06-2012, 08:00 AM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
OP, go to the library and start reading. 2.08 valves do nothing to raise compression. What on that 86 Camaro do you think is strong enough to handle that power? The 700R4 sure isn't in stock form. Tell us what qualifies you to be able to handle a 600 hp car. You do realize that 600 hp at the flywheel will mean you're "street/strip" car will be all strip? C'mon. Educate yourself, put a REASONABLE plan together, and come back.
Old 06-06-2012, 08:09 AM
How fast is fast enough?
A 600hp engine will probably cost you around 10k to build, and you can probably throw away all of the parts you have as they're not even close to cutting it. After you build the engine the car will need another 10k dropped in it to be able to handle the power.
So 20k at 400 a week, you can get it built in about a year.
The next question is do you really want to drop 20k on a 86 z28?
Old 06-06-2012, 12:26 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You guys are going about it wrong here. Just bolt on a 300hp nitrous kit and run it till it blows up....
Old 06-06-2012, 12:30 PM
Well i got the rear end with 3.73 gears, positraction. well i c everyyone is sayin no on 600. How bout alumnium heads with 2.08 valves 64cc, 10.5 to 1 forged pistons, a cam with a lift of 634 nd a team g intake, nd a 750 double pumper. how much hp wud i be puting out?
Old 06-06-2012, 01:13 PM
Listen and Learn
Wiki Edits: 7
Idk what is with the 2.08 intake valve but IMO I would think a head with that size valve is gonna have a pretty big port volume which is gonna kill the low end. I would go with 2.05 if you really want/need the bigger valve. I would think 450hp would be an honest respectable number out of this engine maybe more/less if the cam and heads are sized correctly for the cid, rpm, and application. I haven't had the pleasure to build an aluminum headed 383 yet hopefully soon with finally having a decent job I can put one together.
Edit: Also that rearend is not gonna last very long. I broke mine in my 86 cutlass in a couple months on an under powered 355 with street tires. You will need to upgrade it.
This is where it gets expensive. Everyone wants to make a huge hp motor and they budget for it but then they don't realize the thousands of dollars the drive train and chassis take to make that power get to the wheels and stick.
Old 06-06-2012, 01:31 PM
2.08 intakes? My guess is he's looking at Brodix heads.
Seriously, OP, what is it you want to do? You have to set the car up for what you want to do, then build the engine for what you want to do. The ease in which you backed off from 600 HP tells me you're just throwing numbers out there. Have you even been behind the wheel of a car with an engine that puts out a true 350 HP at the flywheel?
Are you looking for a 12 second car? 11 second car? Even less? I personally think that you just want to drive up to the latest Sonic with a dyno sheet framed in neon on the roof.
Old 06-06-2012, 01:33 PM
Listen and Learn
Wiki Edits: 7
LMFAO! Good old bench racing.
Old 06-06-2012, 02:04 PM
If you could manage a 400hp engine, which I have doubts about, it will destroy your trans, rear, chasis, and even glass...
I'd like to see that video on youtube though... GO FOR IT!
Old 06-06-2012, 02:08 PM
Im jus tryin to get the most hp out of a 383 stroker people. Without spending a **** load of money to get it
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
496 stroker setup schottout Engine 6 04-01-2012 09:52 PM
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
Curious on a High Horsepower Stroker Setup ??? 421strokerguy Hotrodding Basics 19 03-29-2010 10:09 AM
383 Stroker setup questions speedingpenguin Engine 22 08-08-2006 12:29 PM
