383 stroker wiring???HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2009, 06:46 AM
I recently installed my 383 stroker motor in my 1984 chevy monte carlo ss, Has the carb w/ cleaner, headers, fuel pump, and distributor. Pretty much everything in order to get it running... Only thing is i have no clue about where any wires go and which one goes to what part. When i took out the stock 305 i also wanted to get rid of the computer. Every wire that was connected to some part is still in there position but now i dont know which ones still need to be plugged in... Can anyone help me that has some experience, Thanks.
Old 12-01-2009, 07:31 AM
SSedan64's Avatar
This may help you out>> http://www.montecarloss.com/communit...007#Post245007
Lots of good SSMonteCarlo Info on this site. Here also>> http://www.montecarloss.com/
Old 12-01-2009, 08:24 AM
it helps but not 100% It definitly tells me how to get rid of what i dont need but for now i just need to plug in what i need to get it fired up which it doesnt say... So thank you for the very helpfull information as i will save it because i will need that page but i still need to know which wires plugs where for non computer. Thank you
Old 12-01-2009, 10:52 AM
SSedan64's Avatar
Probably the easiest way will be to find another SS owner and check out the wire colors on the Eng. harness. Autozone has wiring & vacuum line diagrams online also. I think you have to signup now to look at them.
I did find this on the SSMonte site>> http://www.badss.net/other/monte_85_wiring.pdf takes a little while to download but it's all there. It's for an 85 but, should be the same.
Other Info here>> http://www.montecarloss.com/technical.html#Electrical
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 09:16 AM
383 Stroker question Houman SS '70 Engine 60 10-30-2009 08:46 AM
383 stroker built...now need cam suggestions Astrodokk Engine 7 01-31-2009 03:53 PM
383 Stroker Question thebellman Engine 3 02-01-2007 03:56 PM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 07:51 AM
