Thread Tools Search this Thread share on Facebook
  #46
Old 04-17-2009, 12:40 PM
y2k600f4 y2k600f4 is offline
Bogie...Could not ask for a better explanation, totally makes sense...you should publish your posts into some sort of manual !!
Well aside from the fuel washing down the cylinders (which apparently is not an issue) sounds like things line up (for the most part)...I guess I will think of the cam change as just an added bonus to target more of my application...
Register now (free) or login to remove ads
Old 04-17-2009, 02:28 PM
roknroy roknroy is offline
Originally Posted by techinspector1
My advice would be not to go picking a cam grind out of thin air until you have measured and computed the exact static compression ratio of the motor and computed the dynamic compression ratio with the intake closing point of the cam chosen.
Further, and I may take some heat for this, but I wouldn't use an extreme energy camshaft. In my opinion, easing up on the lifter rise rate a little with a gentler lobe profile will make the lifter happier. When cams go south, it's the lifter that goes first and then takes out the lobe. If you need more cam, then coordinate the static compression ratio with it and bolt in more cam, but don't ask more from the cam/lifters with an extreme rate of rise than is geometrically sound, again, in my opinion.
I would also take this opportunity to nail down the squish. Measure the stack of parts and the block deck height and find out what the piston deck height will be. From there, you can choose the correct gasket thickness to set the squish. If the block needs to be decked to get the squish right, then deck it. Do it right this time.
Is it possible that you could share the origin of this motor with those of us on the board so that nobody else here will get burned?
i agree, your already against enough odds with a flat tappet cam, with today's oil formulas. i stay away frome, "extreme, black magic, post modern flat tappet grinds. the ramps are too aggresive, based on my experience.
Old 04-18-2009, 03:42 PM
glen242 glen242 is offline
There are different grit hones based upon the type of rings used.
Plate honing is good!
Old 05-08-2009, 11:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Just a nudge to keep this thread in sight.
Hope we hear something good from the OP when he gets rolling again...
EDIT_ Check that- the OP has a current thread, my bad.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
