Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383-- use the vortec heads? what cam?
Old 01-30-2004, 12:27 PM
slonova slonova is offline
hey all.. i purchased a set of complete brand new vortec heads.. a few days later i got an amazing deal on 383, so i had to jump on it. the 383 is about 9.5:1 w/ 76cc heads. the only cam specs i know is that its .490" lift hydraulic flat tappet (its coming out).
should i use the vortec heads on this motor? i dont mind the compression bump, and i want this motor to be pretty streetable. i figure i'd go with the comp cams xe268. will this be too small of a cam for the 383? im kind of limited on the cam with the vortecs, and if i spend the money to get them machined to run a bigger cam, i might as well have bought an aftermarket head.
i could just try to resell the heads and get some dart iron eagles or something..
what do you guys think?
the rest of the setup.. going in a '77 Nova, with a built 700r4, 4.11 gears w/ posi
