383 vortec how much hp tq - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2007, 07:32 PM
383silverado's Avatar
desktop dyno anyone please help
383 vortec 4 bolt main
64cc edlbrock e-tec's
????? which would work better 170cc runner 1.94/1.50 or 200cc runner2.02/1.60 ?????
1.52 compcams roller tip rockers 15-20 extra hp
compcams 206/212 adv. .480/.488 lift 112 lsa
9.8-1 compression forged pistons
6.0 4340 forged rods
3.75 stroke scat cast crank
compcams pushrods
compcams timing chain
will this be a good engine for 3/4 ton silverado 4x4 i think it weighs 6500 lbs just want a good torque motor is this a good combo
any guesses on hp & tq ?
Old 05-17-2007, 11:49 PM
383 vortec how much hp & tq thank you
342hp 474 tq
Old 05-18-2007, 02:45 PM
I would go with the 170cc runners in a 4x4, it will keep the power band lower and keep the tq down low where it needs to be. Your cam choice looks good as well, should be a tq monster. Good luck on the build
Old 05-18-2007, 03:50 PM
RHamm1320's Avatar
Last wiki edit: Computer dyno simulation and engine building softw... Last photo:
Wiki Edits: 3
I am not familiar with truck weights, but 6500 sure sounds high
I agree with the previous post, go with the smaller intake port. The 200cc bigger heads will want rpm and it would take forever to 'get there' with a 4x4
Here is the dyno simulation with the smaller heads:
Old 05-18-2007, 04:08 PM
I came up with similar numbers as the above dyno, 370hp@5250 and 430ft/lbs tq@3000. Should make a good combo, I didnt realize the E-Tecs flow as well as they do. Should have some room in the future to cam it a little more if you would want to. That cam you have picked out is prefect for its use though....good luck man
Old 05-18-2007, 04:45 PM
desk top dyno anyone?
thanks for your input guys it been kinda hard to get reply's on this combo and how much more cam can i go? remember this is a stock efi 4x4
Old 05-18-2007, 04:50 PM
Im not to sure that I would go with much more cam than you have there, is this a stock Vortec ECU your gonna run this thru? I would look into some sort of chip with the combo you have now, as far as more cam I would start where you are at now and see how it runs for you. If you feel the need for more cam in the future, start with a set of 1.6 rockers and then go from there, im sure the E-Tecs wount mind
Old 05-18-2007, 05:07 PM
desk top dyno?
i'm sorry i forgot to mention that i bought the cam and a flash tuner as a combo from comp cams the flash tuner reprograms the computer to match the cam
Old 05-18-2007, 06:18 PM
xr258hr cam
if the xr258hr cam has adv. duration of 258/264 and 112 lsa .480/.488 valve lift with 1.5 rockers. what would be the valve lift with 1.6 rockers?
Old 05-18-2007, 06:28 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What year is your pickup? You're looking at more like 5200-5500 lbs. My extended cab long bed 4x4 tips the scales at about 5700.
Old 05-18-2007, 07:03 PM
97 chevy silverado EXT. CAB 2500 hd 8 lug 8600 GVWR short bed 6 inch lift 20 inch rims 6500 lbs thats what it weighed at the local land fill empty?
Old 05-18-2007, 07:46 PM
RHamm1320's Avatar
Wiki Edits: 3
Wow - that still surprises me. Not saying it wrong at all, just I never imagined they weighed that much.
PS - I have a 2500 too - maybe thats why the gas milage is so low
Originally Posted by 383silverado
97 chevy silverado 2500 hd 8 lug short bed 6 inch lift 20 inch rims 6500 lbs thats what it weighed at the local land fill empty
Old 05-19-2007, 07:36 AM
6426yy's Avatar
.505/.513 with 1.6 rockers if thats the lift for 1.52's and not 1.5's.
Old 05-19-2007, 01:16 PM
your right 6426yy thats .480/.488 with stock 1.5 rockers
All the Vortec engines use a hydraulic roller camshaft and lifters from the factory. here is a paste of the 1996 camshaft specs.
96 L31 Camshaft Profile
Intake:
Max Lift .275 X 1.5 = .412
max lift .275 x 1.6 = .440 .028 difference
Exhaust: s
Max Lift .281 X 1.5 = .423
maz lift .281 x 1.6 = ..450 .027 difference
Lobe Separation 111 Deg.
bassani headers 1 5/8 shorty's
64cc edlbrock e-tec's 170cc runner 1.94/1.50
compcams 258/264 adv. .480/.488 lift 112 lsa
so .480/.488 with 1.5
and .485/.493 with 1.52
and .508/515 with 1.6 rockers
what would be the numbers be with 1.6 at .508/.515 ?
want as much torque as i can get!
Old 05-19-2007, 03:40 PM
engineczar's Avatar
kinda hard to get replies?
How many replies do you want? You PM'd me on Tuesday night and by Wednesday morning I gave you the same numbers that 2 other members have since also given you.
BSE Racing Engines
1968 pontiac heads David Goetz Engine 10 12-21-2006 03:01 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
383 & Vortec? dev Engine 8 08-29-2004 09:01 PM
