Hotrodders Bulletin Board
#46
re: 383 vs 350
Yea,for what your doing,I think a 5.7 rod would be the way to go,in fact,I know some guys only go with longer rods out of necessity,they prefer a shorter one. For what trouble you may stir up and the loss of upper ring landing strength,I would advise to stay with a 5.7. As for the cams you have,the 214/224 would be my choice because it would keep itself cleaned out better and give you a better power feel under acceleration,I really like the comp cams but I think you will find that they both will give you good off factory stall power.
#47
re: 383 vs 350
from the knowledge base:
the rod ratio in a gasoline engine determines the piston dwell at TDC. the longer the rod, the less downwards piston motion will be the result of the rod angle changing. if the crank rotates 10 dergees, then a very short rod will be at a greater angle than fi the rod is very long. since the rod doesnt change length then some of the pistons downwards motion will be a result of this phenomenon, so the longer the rod, the longer the "dwell" and the longer the dwell the more complete combustion and higher cylinder pressure. The rod length is limited by other engineering conserns, like bloch deck height, piston height, and thus inherrent stability, and resultant wear. and so on. In most large cubic inch engines it is hard to get a very high ratio. A Stock 350 Chevy has a 1.64:1 RL/S ratio, which is not very good. By increasing the rod length to 6" the ratio increases to 1.72:1, which is much better. You can squeeze a 6.1" rod in a 350 with little trouble, but longer than that requires plugging the piston pin bores after assembly to support the oil rings. It is not worth the extra expense for the little gains, so a 6" rod in a small-block Chevy has become common because everything fits right in. With endurance engines, longer rods are always better. Most endurance engines are using a RL/S ratio of at least 1.9:1 and some as high as 2.2:1. Before you go out and buy longer rods, let me just say that the gains are very small. This debate has been argued for years and will not end anytime soon. In my opinion, if are building an engine and need new rods and pistons, a longer rod will cost about the same. That makes the small benefits worth it. I would not waste my money buying longer rods if you have a good set of rods that you can use. Use that money to make more power elsewhere in the engine. Rod Angularity A longer rod reduces the maximum rod angle to the cylinder bore centerline. Less rod angle will reduce piston side loading; there will be less friction and less bore wear. Less rod angle also gives better average leverage on the crank for a longer period of time. A 5.7" rod with a 3.48" stroke (stock Chevy 350), will have a maximum of 17.774° rod angle. Switching to a 6" rod will reduce that to 16.858°, assuming that the wrist pin has no offset. (on a ford small block, installing the pistons backwards will actually gain almost 20 Hp. since the piston acts like it was mounted on a longer rod, as the ofset is reversed, at the price of increased noise and wear) Piston Pin Height A higher pin height will reduce piston rock and aid ring seal. please no screaming and name calling about anything about a tighter ring pack, we are talking about pin height and pin height only. Moving the pin closer the the center of gravity of the pistons makes the piston more stable. Rings As the compression height is reduced, the space for the ring pack also get reduced. This can be a problem on some engines. It is good for power to have the top ring as close to the top as possible, but this is limited to the strength of the top ring land. As it becomes thin, it becomes weak. High output engines (especially nitrous engines) need a thicker ring land to keep the cylinder pressure from pinching the top ring. In my opinion, if you have to compromise ring location, it would be better to run a slightly shorter rod. Skirts Shorter skirts are usually combined with a shorter piston for a longer rod, but they are not really related. There is no reason to reduce the size of the skirts just because the pin location changed. A shorter skirts are used to reduce friction and lighten the piston. The cost is a little less stability, but it is arguable that a lighter piston with a higher pin height does not need the extra stability. For a street car, I would increase the rod length if it meant a reduction is skirt size. Most of the things listed here are for competition motors to gain a few hp, not worth a lot of effort for most street engines. Piston-to-Valve Clearance A longer rod decelerates toward TDC and accelerates away from TDC slower than a shorter rod, so piston-to-valve clearances are tighter with a longer rod. This may require deeper valve relief's in the piston (but probably not). A short rod is just the opposite, there is more clearance because the piston decelerates toward and accelerated away for TDC faster. Piston Velocity A longer rod reduces peak piston speeds slightly and delays peak piston velocity until the piston is further down the bore, which gives the intake valve more time to open more. Peak piston velocity is usually somewhere around 75° ATDC and since most cams cannot fully open the cam until at least 106° ATDC, it leaves the valve as a major obstacle when airflow demand is at its greatest. By delaying peak piston velocity, even if it's only 1 or 2 crankshaft degrees, it can allow the valve to open another 0.010-0.015", before peak airflow demand is reached. Not a huge help, but a step in the right direction. With a 350 Chevy, switching to 6" rods from 5.7" ones will delay peak piston velocity from 74.5° to 75.5°. Piston Acceleration / Deceleration Reducing piston acceleration / deceleration from and toward TCD will reduce tensile loading of the rod, the number 1 cause of rod failure. A Chevy 350 with 5.7" rods will have a peak piston acceleration rate of 101699.636 ft/sec/sec at 7000 rpm. Swapping in 6" rods will reduce that to 100510.406 ft/sec/sec at that same rpm. That is a reduction of 1189.23 ft/sec/sec. Intake Runner Volume Since it is easier for an engine to breath with a longer rod, less runner volume is needed. This allows more room for an intake system (this is a very small gain, but is real). Exhaust Gas Scavenging A longer rod is moving slower at TDC, which reduces the speed of the exhaust gasses during the overlap period. This reduces the scavenging effect at low rpm and reduces low rpm power slightly (makes the engine run more cammie). A short rod on the other hand moves faster past TDC and increases the scavenging effect and help low rpm power. Ignition Timing Requirements Due to the fact that the longer rod moves past TDC slower, it gives the charge a longer time to burn. So you need less timing for peak power. Using less timing also reduces the chance of detonation; so higher compression ratios can be used. Switching from 5.7" to 6" rods on a 350 Chevy can allow as much as 1 full point increase in compression. In other words, if you could only run 9.5:1 with 5.7" rods, you could run 9.6:1 with 6" rods. Longer Rod Pros Less rod angularity Higher wrist pin location Helps resist detonation A lighter reciprocating assembly Reduced piston rock Better leverage on the crank for a longer time Less ignition timing is required Allow slightly more compression to be used before detonation is a problem Less average and peak piston velocity Peak piston velocity is later in the down stroke Less intake runner volume is needed Longer Rod Cons Closer Piston-to-valve clearances Makes the engine run a little more cammie at low rpm Reduces scavenging at low rpm Shorter Rod Pros Increased scavenging effect at low rpm Helps flow at low valve lifts (a benefit if the heads are ported with this in mind) Slower piston speeds near BDC Allows the intake valve to be open longer with less reversion More piston-to-valve clearance Can allow for a shorter deck height Shorter Rod Cons More rod angularity Lower piston pin height (if the deck is not shorter) Taller and heavier pistons are required (again, if the deck height is not reduced) More ignition timing is required for peak power |
#48
re: 383 vs 350
i found a place on ebay to get a stroker kit for a 383 that comes with a eagle crank,eagle rods ,speed pro pistons,rings ,clevet bearings ,flex plate, balancer,and balanced on a hinds machine for $700 . |
#49
re: 383 vs 350
search about scat and eagle cranks, I've heard nothing but bad things about those low dollar cast cranks. For more information, PM or message Machine shop tom
K |
#51
383 vs 350
Yikes, I've been watching the Ebay 383 kits and motors.I have noticed this time around the bearings aren't Clevite (?)77. The kits seem to have quality parts names.They certainly are cheaper than anything I can get in Canada.What happens with Scat cranks? Thought steel cranks were good.What do i look for in a crank?
Ted |
#52
re: 383 vs 350
those low dollar cranks have uneven runout and I've heard of bad rodside clearances that basically just chew your bearings to garbage! Of course this is not with all of these cranks, but think about it; if you buy a 150 dollar crank that needs 80 bucks worth of machine work, a 350 dollar crank that is going to be right and isn't going to eat up two weeks of machine time is worth the bux. Plus cranks are a lifetime item (well, close) much like a set of heads. I always buy the best stuff I can get, because the better the stuff you buy, the more motors you can build with it!
K |
#53
383 vs 350
LOL, gee thanks Killer, thats good advice and very deep. :o) Ted
#55
Stroker is A+
A Strokers the way to go. You get BIG BLOCK torqe and up the HP, but it still small block wieght. If you willing to spend time perfecting timing, tuning and the right Trans (700r4), Ive heard people brag on 23mpg. No joke..... best of LUCK
StrokeofGenius |
#57
350 nor 383
I will not argue this point with anyone it is simple if you don't understand here it is:
350ci has 4" bore 400ci has 4.125 bore Bore---------------------------------------Stroke------------------------------ x..........................3.00"............3.25".............3.48"...........3.75" 3.500"].................................................. ........267ci .......................... 3.736"]................263ci............285ci............ .305ci............329ci 3.750"]................265ci............................. ............................ 3.875"]................283c............307ci............. ..328ci...........354ci 4.000"]................302ci...........327ci............. ...350ci....372ci (383*) 4.125"]................321ci...........347ci..........372 ci (377*).....400ci *Designates .030" overbore typical of this combination Factory bore/stroke combinations are linked to a typical application swpping the 350's 3.48" crank for the larger 3.75" stroke will increase to 383ci at .030 but why give up cubes buy killing the potential bore size from 4.155 to 4.030"? build a .030 over 400ci "406" as long as you drill the steem holes in the heads you'll have no mistery overheating issues. you'll have more power down low and reach peak power potential of your induction system sooner There are shorter pistons available to increase rod length for increased rod stroke ratio which is great for top end but on the street "bad ratio is actually bennificial in increasing piston speed at low cruise speeds and effectivly increasing signal to the carb. there are a million ways to build a motor but total combination is what is most important. If you want it all in under 5000 406 is the way to go, for millage you are beat the fact is if you want to make power you have to burn fuel. My recomendation for fuel economy and performance is forget the steep gears in the rear, you will not need with the mounds of torque you'll have with a 406ci keep it in the 3.23-3.5 range depending on rearend, and sellect either a vacume secondary or a spread bore caburator like a rochester, carter, holley 1460. I like rochesters the only guys who don't just don't have a clue about how to tune them. You might also want to try an overdrive transmission like a 700r4 or 2004r. I ran low 11's with a similar combo in an daily driver astro van. If you want any more help or info feel free to ask! as far as parts go I used factory short rods "Cast crank" factory block, heads (ported) and was fine If you aren't building a race motor and aren't looking for more than 450-475 horse power factory parts are just fine. most problems encountered with cheaper parts aren't the fault of "cheaper parts" it's the "cheaper builder" Last edited by BIGSHOOTER : 11-14-2004 at 06:12 PM. |
#58
383 vs 350
I'm overwhelmed at how much this is going to cost me to do my 38 Chev.So I'm going with a 350.I have a 4 bolt main CSB that I think is good.I'm going to take the heads off,do the valves and port it.Check the motor out a bit, it ran OK.Then I have a Holley 600, Edelbrock Performer and just need a cam and headers.I've phoned Crane and Comp each twice and they have recommended 4 different cams,LOL.If they don't know, how can I?I'm thinking RV cam,204/214.Can't spend too much on this , my other hobby,raising cats, cost alot also.
Ted |
#59
re: 383 vs 350
Use the Edelbrock Performer cam and don't worry too much about it. Unless you switch to a camshaft with fairly radical lobes, solid lifters or a hyd. roller, you won't see much of a power difference.
The Edelbrock setup works nicely. Larry |
#60
re: 383 vs 350
The summit k1102 has the same specs and comes with lifters that you will need too for 79.95,do you think it is the same cam with a plain white box? Hmmm,makes you wonder. How much does advertising cost?
