383 wall thickness for 100hp shot?
I'm building an LT1 into a 383 pretty much per these specs.
My question: is .20 the minimum cylinder wall thickness for a 100hp shot of NO2? What are my chances of still having that much left if they take .030 from the bore? |
A buddy of mine, I believe it's a LT1, has a TA and sprays a 250 shot. Stock bottom end. He eventually cracked a head I believe due to heat, AFR, but the short block held together after MANY, MANY passes. He was quite surprised how well it's held together.
Best thing to do is have it sonic tested before spending alot of money in machine work, The block does not have to be cleaned to have it sonic tested either.
I would look for at least .180 on the thrust at finish and at least .120 on the wrist pin side at finish bore. Good luck |
Thanks to all of you. I'm feeling better about my plan - lets hope I get good news from the machine shop!
| Push Rod Wall Thickness - BBC | leejoy | Engine | 1 | 03-18-2008 10:18 AM |
| Minimum cylinder wall thickness | joe_padavano | Engine | 2 | 09-27-2007 12:17 PM |
| 383 silverado update | 383silverado | Engine | 17 | 09-19-2007 09:28 PM |
| Frame wall thickness | pigman | Suspension - Brakes - Steering | 18 | 05-31-2005 07:12 PM |
| Shot Peening - Interesting Read | dbuff | Engine | 0 | 09-02-2004 12:43 PM |
