Thread Tools Search this Thread share on Facebook
  #1
Old 01-03-2012, 06:53 PM
65elky 65elky is offline
383 withe afr 195 heads 241-247 howards retro roller
iv have just put together a 383 10.8-1 comp howards 241-247 at 50 and 545-565 lift on a 110 lsa and afr 195 eliminators eddy air gap rpm not in car yet maybe 2wks will be installing any guesses how this combo will run
Register now (free) or login to remove ads
Old 01-04-2012, 05:55 PM
383 afr
???? any ideas
Old 01-04-2012, 06:19 PM
joelster joelster is offline
Run as in ET? Or run as in hp?
ET--no idea since I don't know what car it's going into.
HP-i'd say an easy 510 at the flywheel. Closer to 540 if everything is done perfect. What afr's are they? Are they the race ported or the comp ported?
Old 01-05-2012, 06:39 PM
383 afr
mainly hp i have the 195 street eliminaters going in 65 elcamino 3500 converter th350 rpm air gap 10.8-1 compression 545-565 lift 241-247 duration at 50 retro roller on 110 lsa 750 holley dp oh yeah and 3.73 gears
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "383 withe afr 195 heads 241-247 howards retro roller"
ThreadThread StarterForumRepliesLast Post
retro hit hyd roller cam in oe roller block?973kgtEngine407-26-2010 08:54 AM
Cost of retro-roller vs OE roller setup on SBCv8hedEngine1308-03-2009 05:04 PM
SBC Factory roller lifter retro on non roller block383ramEngine101-24-2009 07:16 PM
roller cam retro fitDARIN ALLMANEngine1412-17-2007 04:29 PM
Retro fit roller camdboyett38666Engine1605-01-2006 04:17 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
