Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383HT exhaust recommendatations
Old 12-28-2012, 03:32 AM
gearheadslife gearheadslife is offline
Banned
I'd make a template out of paper or posterboard of the head ports and bolt holes, then check the rams with the template and see how much different the ports line up..
not knowing what heads you're use'n.. but if those ram horns are from a g.m. truck.. the ports on the old engines and the exhaust ports on newer heads are not the same.. and iff a tad off, open up the horns.. I'd go to 2.25 pipe as soon as you can off the horns..
