385 fast burn engine
i have a 385 gm fast burn roller engine with a fact installed 383 roller cam , what can you tell me about these motors , it runs great but is it normal for these engine to be noicey on start up tell warmed up,sounds like valve noice but valve adjustment was checked and is rite zero lash and a 1/2 turn thanks jim
classic result of forged pistons, if theres no blowby present then theres no reason for concern
Forged pistons are known for more expansion, larger ring gaps are my reasoning for assuming a forged piston had more expansion properties vs other hardening/manufacturing techniques,guess i was wrong. the 385 had hypers?did not know that till now,maybe i should not have been so eager to reply, next time i will make sure before hitting that reply now button..
![]() To the op, sorry.. Maybe your lifters are bleeding down and ticking, i know you said till warmed up but, approx how long before the noise goes away? And how long does the engine sit when it happens? Last edited by sri3850341; 02-22-2011 at 10:46 PM. |
Your question wasnt dumb either. You ask questions cause you dont know, you ask questions when you wanna find out. When I was in college i raised my hand all the time like I was in grade school. People usually asked me for info cause they knew if i didnt know the answer Id raise my hand and find out for all of us. Never think a question is dumb
One of my college professors use to always say "if you cant learn continuosly the world cant use you" |
To SRI....Hell I don't know all this stuff, Google is your best friend!! Most of the questions asked can be googled for the answer. One of the worst ones is "what does my sbc casting number mean?"
The cam has a lot of lift w/o a lot of duration, and uses stamped steel rocker arms. This can contribute to some 'extra' noise. This would be heard from the top of the engine, at the valve cover level. If you're hearing something lower on the engine block, this could be caused by a piston(s) w/the skirt partly collapsed from overheating, or a loose wrist pin, or even excessive bearing clearances. |
| GM Fast Burn Heads | bigjoedo | Engine | 4 | 01-02-2007 10:46 AM |
| Fast Burn heads | engineczar | Engine | 3 | 02-10-2006 08:37 PM |
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
