385 Gu Ru HELP. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2005, 08:52 PM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
385 Gu Ru HELP.
My '73 Murcury 429 - Intake Gaskets Seam to be a problem, My aluminum Tunnel Ram. don't fit Exactly. Did some 429s need a tin baffle. with gaskets on each side? The Block & Heads were reserfaced. The deck highth Varried; Through the years; could that be the problem?
Old 12-26-2005, 10:16 PM
BOBCRMAN@aol.com's Avatar
Assuming that your intake wasn't cut for a radical engine...Yes there are a couple of different intake gaskets available for the 429-460 engine. The stocker type has a sheet metal tray with paper port gaskrts. The High Perf sets are available with no tin. Just the head and end rail seals.
Old 12-27-2005, 09:02 PM
Intake Gaskets 429/460 Ford
I HAVE THE C.J. SET. The vertical bolts seam fine; the angle bolts don't tighten to the gasket like they should - there is a gap, when quite tight.
I don't want to make the holes any bigger; unless I have to.
I think I'd rather do it with gaskets. [ End Rubber ones look good. ]
Best heads for a Blown 385? Torque Engine 2 10-04-2004 10:25 PM
385 fast burn crate motor camaroconvert69 Hotrodders' Lounge 9 06-15-2004 11:03 PM
385 series id D1VE-A2B Jared Engine 6 01-21-2004 10:22 PM
Lowing compression in built chevy 385 68rsss Engine 2 06-03-2003 05:36 AM
