385 sbc s-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2013, 09:55 PM
377tk's Avatar
385 sbc s-10
I recently traded vehicles and got a s10 with a 385 sbc its all forged scat rotating assembly with ross flat top pistons 10.5 to 10.75 to 1 compression. It has sportsman 2 heads with 200cc runners and 64 chambers. The cam is comp cams large nitrous hyd roller 284/315 duration 236/248 520/540 with 1.5 rockers. I am running 1.6 roller rockers. It has a port matched super vic intake and a 830 annular carb for nos currently running a 650 double pumper on it. I am running and electric water pump and a th350 with a 4k nitrous stall and 3.73 gears soon to be an 8.8 rearend with 4.56's. Anyone running a similar combo? I am guessing just by comp cams cam quest to be about 50hp less than they are saying which would put me at about 500hp am I in the ballpark or off pretty far camquest said 543hp. Any input would be cool. I have nitrous but not on it right now and will be spraying a 125 shot in the near future. In the process of getting it licensed and on the street then get it to the track hoping for low 11's on motor. thanks for your input.
Old 06-08-2013, 12:50 AM
vinniekq2's Avatar
thats a very big intake for a hydraulic cammed engine?
The 650 carb will not flow enough to make 500 HP
Old 06-08-2013, 08:56 AM
377tk's Avatar
650 is temp u til I get the 830 tuned to the engine
Old 06-08-2013, 11:48 AM
vinniekq2's Avatar
have you considered an RPM intake,or vic jr?
Old 06-08-2013, 01:12 PM
377tk's Avatar
just picked a stealth intake up today need to port match the runners
New built 385 SBC Dieseling hotrod937 Engine 32 07-12-2012 12:04 AM
help with 385 sbc 88camaro385 Engine 22 07-11-2012 08:23 PM
help me find a gead gasket for a 385 sbc TMF Lindbeck Engine 2 04-04-2011 02:47 AM
SBC 385 on Juice help! ChevySDime385 Engine 7 11-25-2010 03:36 AM
My 385 SBC solid roller build hotrod937 Hotrodding Basics 4 02-24-2009 02:22 PM
