388 Chassis Dyno - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2012, 03:35 PM
Greg T's Avatar
www.krusinklassics.net
388 Chassis Dyno
Results....FINALLY! After a couple of years of tuning and tweaking I had a chance to put my 388 SBC on a chassis dyno. Here are the numbers.
H.P. = 380
T.Q. = 396
All in by 5800 RPM. This is in a 96 C1500 shorty box with TH350 trans. I'm pleasantly surprised and happy with these numbers.
Old 06-03-2012, 09:08 PM
Greg T's Avatar
Off topic? Really? What a way to kill a thread.
Old 06-03-2012, 11:06 PM
68NovaSS's Avatar
Wiki Edits: 9
It's always been board policy to move threads without technical questions and those with no technical content or value, from the tech forums to a general discussion forum, not necessarily Off Topic.
By the same token, hp and desk top dyno requests are routinely moved to Basics.
From the board guidelines:
*Engine -- this forum covers all engine questions, from intake to exhaust, and everything in between.
*Hotrodders' Lounge -- this forum is for non-technical automotive discussion. Anything that has to do with automobiles, but isn't a technical discussion, can be placed in the Hotrodders Lounge.
I'm moving your thread from Off Topic to the Lounge.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 06-04-2012, 06:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
H.P. = 380
T.Q. = 396
Sounds good for that low of a peak. What are the specifics on the engine (cam, induction, exhaust, heads, compression, etc.)?
Old 06-04-2012, 10:34 AM
Greg T's Avatar
.060 over 1979 350 block with 3.75" stroke, 10.6:1 compression, Edelbrock Etec 200 heads, Ede 2201 roller cam, roller rockers, Air Gap intake and a QFT 680 cfm carb. MSD e-curve distributor and 6AL box. Electric fuel pump, electric water pump and cooling fan.
Engine dyno to chassis dyno numbers dedub Engine 3 06-19-2011 07:56 PM
chassis dyno hp to engine hp zephyrc General Rodding Tech 1 06-16-2011 02:19 PM
Chassis Dyno's in NW Ohio?? Steel Engine 2 12-28-2009 02:16 PM
Used SBC 388 dyno test 71C10 Engine 11 12-13-2006 05:31 PM
Chassis Dyno vs Flywheel 428ho Hotrodders' Lounge 1 10-23-2006 06:55 AM
