388 stroker oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 08:37 PM
dgmalibu10's Avatar
I Hope Somebody Can Help, I Have 388 Stroker With A Turbo 350 Transmission, I Have Oil Coming From Some Where, After Driving The Car For A Few Blocks And Getting On It Once Or Twice The Car Spits Oil From Some Where, I Tried The Oil Sending Unit, The Valve Covers, The Two Holes By The Timing Cover, The Rear Main Seal, I Cant Find It. When I Race The Motor The Right Side Of The Motor Starts Smoking From Oil Hitting The Header. Theres Oil All Over The Top Of The Motor. This Is A Fresh Build, Only About 100 Miles On The Motor. Any Ideas Would Be Great, Thanks
Old 07-23-2010, 05:40 PM
bubbahotep's Avatar
You got the pcv line connected? might be high pressure causing the leak.
Old 07-23-2010, 06:46 PM
dgmalibu10's Avatar
yes, i do have a pcv, im thinking its the valve covers
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
Environmentally friendly honing fluid. F-BIRD'88 Engine 16 07-01-2007 10:06 AM
clues needed for 460 oil leak cboy Engine 2 07-21-2006 02:32 PM
Oil Leak pjarrett Engine 11 07-03-2006 10:38 AM
Oil leak at MSD distributor base? TVR383 Engine 2 10-28-2005 03:37 PM
