Thread Tools Search this Thread share on Facebook
  #31
Old 02-15-2009, 08:05 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
That's an intelligent question 71nova1. Sometimes the outer inertia ring of the damper slips on the elastomeric material between the inertia ring and the inner hub. When that happens, there is no way to use a light to time the motor. I wrote an article for the wiki and I'll refer you to it.....
http://www.crankshaftcoalition.com/...top_dead_center
The reading of the article is worse than the actual procudure, it's just that when I write something, I try to make it very detailed and bulletproof.
Register now (free) or login to remove ads
Old 02-15-2009, 08:07 PM
71nova1 71nova1 is offline
71 Nova Guy
ok thats what i thought, well i will do this toomarrow, its too cold out side right now, its 36 degrees i sure that would make a difference, toomarrow should be 60 out so that should be just warm enough. I will post toomarrow and we will see how i was taught or how I listened,lol. I am running ac delco plugs, Is that a good plug for that? I have msd ignition.
Old 02-15-2009, 08:31 PM
71 Nova Guy
http://www.corvette-restoration.com...s/Timing101.pdf
I read this article, I have now learned even more. Its an awesome source of information.
Old 02-15-2009, 08:34 PM
roknroy roknroy is offline
autozone and gm sell harmonic balancers that are very affordable...
Old 02-15-2009, 08:47 PM
Senior Curmudgeon
Wiki Edits: 326
Yep, and you can get a quality rebuilt unit from my favorite damper vendor, Damper Doctor.
http://www.damperdoctor.com/Merchan...T&Store_Code=DD
Old 02-15-2009, 08:50 PM
71 Nova Guy
The one that is on there only has 2000 miles on it, so i didnt think to change it, I will check the tape and everything toomarrow, but i think it will be fine. What type of spark plugs do you think i should use??
Old 02-15-2009, 09:03 PM
find out the year, make, and model your heads came off of, and use the original ac plugs. i have been in the auto parts business a long time, and it makes a difference. at least start there.
Old 02-15-2009, 09:04 PM
71 Nova Guy
the heads are vortech heads from jegs
Old 02-15-2009, 09:13 PM
ac delco 41-993 plugs. these were designed with those heads...
Old 02-15-2009, 09:44 PM
runn141's Avatar
runn141 runn141 is offline
SB S10
ac delco r44lts plugs are a conventional plug for those heads also.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "388 Stroker timing help.."
ThreadThread StarterForumRepliesLast Post
Chevy 383 Stroker timingHotrodder78Engine403-15-2009 11:15 PM
Gear Drive to Timing Cover ClearanceDouble_v23Engine501-11-2008 11:08 AM
ignition timingbad502Engine2102-20-2006 06:57 PM
stroker timing ????wheelerexHotrodders' Lounge005-25-2004 01:30 AM
Timing 383 stroker.TVR383Engine204-20-2003 06:58 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
