Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 388ci heads and cam recommending
Old 11-22-2012, 10:00 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
what do the heads flow? how many CFM at what valve lifts? while you are there,get the intake manifold flow tested.Are you custom building the headers? what will you use as a CR? How many RPM will the engine be engineered for? Are you using shaft rocker arms? Do you have a carb yet?
