Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 388ci heads and cam recommending
Old 11-22-2012, 03:17 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Here's the low-down on the pistons, with projected static compression ratios.....
SRP 140350 Chevrolet 388 stroker high compression forged pistons
That manifold was apparently designed to work with the raised runner Bow Tie heads.....
http://www.gmpartsdirect.com/perform...CATID=995.html
Static compression ratio will be nearly 15:1 and this motor should produce over 700 hp in my opinion. It is also my opinion that the production block will begin disassembling itself.
