-   Projects/Builds/My Ride (http://www.hotrodders.com/forum/projects-builds-my-ride/)
-   -   389 build (http://www.hotrodders.com/forum/389-build-231883.html)
LATECH 04-15-2013 05:12 PM
389 build
1 Attachment(s)
This is a shot of my fresh 389 build. I have some detail work to do in the engine compartment but she's in there and runs strong.:)
The Crosswinds intake manifold raises the carb up about 1 1/2 inch above the stock intake, good thing the hood still closes.:thumbup:
http://www.hotrodders.com/forum/atta...8&d=1366067543
LATECH 04-15-2013 05:14 PM
1 Attachment(s)
Of course the sled that it is in needs completly refinished....thats next.
http://www.hotrodders.com/forum/atta...0&d=1366067683
Onefunponcho 04-15-2013 05:33 PM
Nice
Great looking old poncho mill :thumbup:
LATECH 04-15-2013 06:18 PM
Thank you. It has a good GROWL too. 9.5 to one zero decked,bored to 4.120, crane 272-2 screw in studs, mild porting.....:thumbup:
Onefunponcho 04-17-2013 07:50 PM
Did you block the heat cross over under the intake? Also what rear gear do you plan on teaming with that cam?
LATECH 04-18-2013 04:30 PM
The intake blocks the heat crossover and is assisted by a Mr. Gasket intake set with the metal patch for over the hole too.
The stock rear in it is a 3.23 8.2 rear.
I will be upgrading to a LSD in the future. I am going to add a LSD carrier to the 8.2 untill it pukes, if it does, then I will move on to something stronger like an 8.5 or 12 bolt, maybe a moser or strange. We will see.
I have a few bugs to work out this weekend and I am hoping to go on its maiden cruise next week sometime after I tag it.
LATECH 04-18-2013 04:32 PM
Crosswinds by professional products
1 Attachment(s)
This is a crosswind intake by professional products. Quality is very good. Casting is clean and has no flash, runners looked good, also has about 1 1/2 inches of rise over stock P4B.:D
