389 build - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 04-15-2013, 06:12 PM
LATECH's Avatar
389 build
This is a shot of my fresh 389 build. I have some detail work to do in the engine compartment but she's in there and runs strong.
The Crosswinds intake manifold raises the carb up about 1 1/2 inch above the stock intake, good thing the hood still closes.
Fact is stranger than Fiction
Old 04-15-2013, 06:14 PM
LATECH's Avatar
Of course the sled that it is in needs completly refinished....thats next.
Old 04-15-2013, 06:33 PM
Onefunponcho's Avatar
Nice
Great looking old poncho mill
Old 04-15-2013, 07:18 PM
LATECH's Avatar
Thank you. It has a good GROWL too. 9.5 to one zero decked,bored to 4.120, crane 272-2 screw in studs, mild porting.....
Old 04-17-2013, 08:50 PM
Did you block the heat cross over under the intake? Also what rear gear do you plan on teaming with that cam?
Old 04-18-2013, 05:30 PM
LATECH's Avatar
The intake blocks the heat crossover and is assisted by a Mr. Gasket intake set with the metal patch for over the hole too.
The stock rear in it is a 3.23 8.2 rear.
I will be upgrading to a LSD in the future. I am going to add a LSD carrier to the 8.2 untill it pukes, if it does, then I will move on to something stronger like an 8.5 or 12 bolt, maybe a moser or strange. We will see.
I have a few bugs to work out this weekend and I am hoping to go on its maiden cruise next week sometime after I tag it.
Old 04-18-2013, 05:32 PM
LATECH's Avatar
Crosswinds by professional products
This is a crosswind intake by professional products. Quality is very good. Casting is clean and has no flash, runners looked good, also has about 1 1/2 inches of rise over stock P4B.
389 overheating baadgoat65 Engine 33 05-01-2013 03:10 PM
64 Pontiac 389 to 65' Pontiac 389 environspec Engine 4 02-17-2013 10:07 AM
389 Goat cujoky Engine 5 10-26-2011 11:22 PM
Help 383-389 Vortec Motor Build this winter Impala5967 Hotrodding Basics 6 09-20-2011 04:06 PM
65 Goat 389 Build mael64 Engine 0 12-03-2002 06:05 PM
