389 overheating - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-10-2010, 05:35 PM
is the divider plate properly spaced from the impeller on the water pump i know from experience if its not close enough all the water does is kinda slosh around by the pump and almost none makes it through the engine had that problem
  #17 (permalink)
Old 07-10-2010, 05:47 PM
its interesting that your 389 doesn't have this timing cover and has the twin plate design i thought 389's had this one
  #18 (permalink)
hot 389
i wish it was somthing that dumb i just checked the timing andit is 6 btdc and my timing light says to run at 2k to check the advance so it comes to 12 plus the 6 initial time and it comes to 18 total with the car running at 2k wile i checked the adv timeing it got to 215 deg and stayed i hooked up vacumn adv and it was still 215 so i held motor reved to about 2700 rpm and it came down to 213 deg then when i let it go back to idle it shot up to 230 and when you let of gas it would go to 0 oil pressure for a second and then come up to about 5 lbs so i shut it down
  #19 (permalink)
Old 07-10-2010, 05:54 PM
I question your timing checking. At 2000, 12BTDC or 18BTDC is not enough. Run the engine to 2500 and set advance with vacuum pot unplugged at 36BTDC. The retarded timing will cause excessive cylinder head heating.
The low oil pressure is troubling.
  #20 (permalink)
hot 389
that photo mite be a 69 motor they changed the timeing cover that year i mite be looking for a motor so if you have any good sorces for engines let me kn ow thanks
  #21 (permalink)
Old 07-10-2010, 06:22 PM
you said its all new so im assuming its just been rebuilt if thats the case how far has it been driven since its been rebuilt have you changed your break in oil yet that may fix your oil pressure for the most part.. is your radiator new or is it the original ...
  #22 (permalink)
Old 07-10-2010, 06:29 PM
sqzbox's Avatar
My pipes are my music
If your tri power isn't new it might have come off an old 421. Way to rich for a 389.
  #23 (permalink)
Old 07-10-2010, 08:49 PM
hot 389
the carbs are remaned from performance years they are supposed to be the correct internal parts i have no idea what to do next do i need a kit to get more mechanical advance on the distributor and richen up the feul mixture do any of you guys think it could be a problem with the heads or internal somwhere i am close to pulling the moter and replacing it with a 400 but i wanted to keep it as original as possible and i dont know if my tripower set up will fit a 400 oh well let me know if you guys think of anything else
  #24 (permalink)
Old 07-10-2010, 10:01 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Running rich is not causing your over heating problem.
Semper Fi
  #25 (permalink)
Old 07-11-2010, 11:41 PM
WDCreech's Avatar
Grumpy Old Goat Herder
baadgoat, have you checked the total timing? If your mechanical, or vacuum advance is not working, it would cause over heating because of slow timing.
  #26 (permalink)
Old 07-12-2010, 12:10 PM
hot 389
hi yes i have checked the timeing if i am doing it corectly i have 6 deg btdc and 12 deg at 2000 rpm total of 18 deg thats with the vacumn advance disconnected could a bad valve or anything like that be possible and carberator mixture it is in for rich and out for lean rite or did i get that wrong thanks for your help let me know what you think
  #27 (permalink)
Old 07-12-2010, 12:13 PM
sqzbox's Avatar
In lean, out rich.
  #28 (permalink)
Old 07-12-2010, 12:15 PM
sqzbox's Avatar
A vacuum gauge is what you need if you want to get it set just right or as good as it can be. aim for 20# of vacuum at adle speed or as good as you can get it if you have a HP cam in there.
  #29 (permalink)
Old 07-13-2010, 11:39 AM
hot 389
i noticed my front brakes get so hot that they start holding on and my pedal gets hard could my master cylender be getting to hot i stuck my finger in the fluid and was not hot would my power booster cause the brakes to hold when it gets hot i ajusted the timing and carbs again as long as it is moving and doesnt get stoped at lights or anything it will stay around 180 and if you can move at a good speed no sloww driving but if you let it set and idle it will get to about 230 it starts loseing oil pressure around 190 to 215 it gets low it doesnt lose it all together i am about to put new calipers and master cyl and booster and a new enine and tranny i forgot to mention that when it gets hot the tranny starts lossing 3rd gear i am so pissed anyone live around new castle pa that could help let me know thanks
  #30 (permalink)
Old 07-13-2010, 12:17 PM
WDCreech's Avatar
It sounds to me like you have a brake line that is too close to the exhaust.
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 05:03 PM
1964 Pontiac 389 Rebuilt (74' 400 Heads) - Have questions... gen_x_forever Engine 15 11-14-2010 12:42 PM
68 camaro RS w/ 454 overheating rakundig Engine 22 09-14-2006 09:52 PM
389 overheating armyaj33 Engine 10 03-23-2004 05:58 PM
overheating problem armyaj33 Hotrodding Basics 9 03-05-2004 05:31 PM
