389 overheating - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-13-2010, 11:27 AM
sqzbox's Avatar
My pipes are my music
Your tri-pwer setup should bolt right up. I did that to a 69 400 from an earlier year 389 and it worked pretty good till I got fed up with the constant adjustments to keep it running good as I only re-built the center carb. Went back to a 650cfm holley and actually got better performance and drivability.
  #32 (permalink)
Old 07-13-2010, 02:52 PM
hot 389
i will check that i do have the ones that go to the front that look to be a little close thanks for all your help
  #33 (permalink)
Old 07-13-2010, 05:15 PM
40forddgc's Avatar
heating
make sure the upper radiator hose doesnt go upwards before entering the intake. I had a similar problem> I had an air pocket and the water wasnt flowing enough. Good luck anyway.
  #34 (permalink)
Old 05-01-2013, 02:10 PM
Overheating
I had my 389 rebuilt and it overheated and vapor locked after it warmed up. I could only drive it about 1/2 miles and it would vapor lock, i would let it cool down and it would start again. What I found out was the intake gaskets cross flow under the carb were wide open, wrong intake gaskets. I put the correct ones in that had the middle port blocked off (I have an electric choke but if you have a thermo choke you will need to install the ones with a very small hole) and the vapor lock up stopped. Bottom line when I checked the intake mantifold under the carb was hotter than the exhaust mantifold. You might want to look at that for the vapor locking.
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 04:03 PM
1964 Pontiac 389 Rebuilt (74' 400 Heads) - Have questions... gen_x_forever Engine 15 11-14-2010 11:42 AM
68 camaro RS w/ 454 overheating rakundig Engine 22 09-14-2006 08:52 PM
389 overheating armyaj33 Engine 10 03-23-2004 04:58 PM
overheating problem armyaj33 Hotrodding Basics 9 03-05-2004 04:31 PM
