389 overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2004, 06:36 PM
New Member
389 overheating
i need some help, i have a 65 pontiac lemans w/ a 389. it is overheating pretty quickly while at idle. i have no thermostat currently in and while idling with the radiator cap off i really didnt observe any flow, temp reached 210 degrees. i shut it off and stuck my finger into the radiator and the fluid was pretty cold, is this a water pump problem or possibly some other type of flow problem. any ideas would be greatly appriciated!!!!
Old 03-06-2004, 06:38 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
collapsed hose?
radiator blockage?
Old 03-06-2004, 06:41 PM
New Member
oh yeah
i just recently re installed my original freshly recored 4 core radiator!
Old 03-06-2004, 07:06 PM
air in the system some where.
Old 03-06-2004, 07:14 PM
New Member
how do i get rid of an air lock
if there is air in the system, any tips to get rid of it?
Old 03-06-2004, 07:24 PM
hmmmm.....
if you have no t-stat in.....
and ran it with the cap off.....
and it heated up to 210.....
no coolant circulation......
is the cap located at the highest point in the system?
is there anywhere you can open it up to vent at a higher location?
how old is this h20 pump?
doh' i can't believe i forgot, how old is the sending unit to your temp gage?
Old 03-06-2004, 07:28 PM
New Member
brand new temp gauge and sender
the filler neck i believe is at the highest point, and the water pump i believe is pretty old!!!!!!!!!!!1
Old 03-06-2004, 07:34 PM
man i hate to change a h2o pump.
oh, wait, i'm not!
i can't think of anything else.....
last time i had overheating problems, i replaced every freakin' thing except the sending unit. and you know that's what it was......
i'd try a new pump if the one on it has been there awhile....
you didn't say why you had the rad recored.... if it was nasty, you could very well have a wore out pump.....
besides, a newly recore radiator deserves a new h2o pump
Old 03-06-2004, 09:33 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
when my cav was overheating it was due to a faulty thermostat...
edit: i just saw you were running no tstat...its a freakin 6 dollar part and well worth the 6 bucks
Old 03-07-2004, 12:49 AM
Magikal's Avatar
How can it go faster?
Last journal entry: Been a long Winter
quote: i just saw you were running no tstat...its a freakin 6 dollar part and well worth the 6 bucks
Amen!! I would pick up a new water pump, t-stat, and maybe a hose or two, flush the entire system good (especially the radiator, even a new one if the $$ allows). That oughta fix any overheating for awhile.
Old 03-23-2004, 04:58 PM
New Member
think i figured it out
when i took the waterpump off( remeber pontiac water pump is like 3 pieces that attatch to the timing cover, wish i knew this!!!) and found out after a whole lot of trial and error that my water pump was missing the internal housing and divider plates from with in it. i just ordered these and hoping it will fix, anyone think this couldve been the cause. and yes bought a new thermo stat and temp gauge!!! man i hope this solves the prob
