389 pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 03:57 PM
389 pontiac
does anyone know if 1964 heads of of a 389 will fit a 65 389 i ran into a problem i have a show condition tripower set up of of a 64 389 but my engine is a 65 389 i was hoping i could put a set of 64 heads on the engine and i could use the tripower set up anyone have any ideas thanks
Old 06-08-2008, 08:38 PM
Will I ever get it done?
Last journal entry: Hood
I knew that in 67, they changed the valve geometry so I didn't think the piston valve reliefs are in the right location after 66. But I wasn't sure how far back you could go. According to Wallace, you can interchange 61-66 heads.
http://www.wallaceracing.com/interchange.htm
You should be OK putting the 64 heads and intake on your 65.
Old 06-09-2008, 12:23 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Agreed. The transition year was 66-67, but even so the only real difference was pushrod length. I didn't have any valve relief problems putting 73 heads on my 66 389.
Old 06-09-2008, 10:43 AM
WDCreech's Avatar
Grumpy Old Goat Herder
The blocks are the same. As long as you use the 64 heads w/the 64 intake, you're good to go!
ID:	30504   Click image for larger version
ID:	30505   Click image for larger version
ID:	30506   Click image for larger version
ID:	30507   Click image for larger version
need help pontiac 389 with 400 heads RedFox Engine 4 12-29-2007 09:41 PM
Pontiac 389 with HEI kreuzn1 Engine 2 03-29-2007 06:27 AM
pontiac 389 or 400 Rufus_2 Engine 3 04-01-2006 03:39 AM
63 pontiac 389 1967bird Introduce Yourself 1 11-22-2004 06:53 PM
pontiac 389 broken rocker stud tree_entz Engine 4 06-08-2004 12:29 PM
