389 Pontiac build - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 05-14-2013, 05:30 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
389 Pontiac build
Well ....... it is finally together and running.
Here are some pics to check out.
Engine is a 65 389
bored to 4.120 (400)
balanced
Decked to .005
80 CC heads
Mild port work
1.77 exhaust valves installed
screw in rocker studs
crane 272-2 cam
crosswinds intake
Q jet
dizzy has been recurved
2.5 inch dual exhaust with H crossover
Notice the heat crossover is blocked By the Bodacious intake.
Fact is stranger than Fiction
Old 05-14-2013, 05:32 PM
LATECH's Avatar
Whoops ...forgot the goodies
Here they are....
ID:	74014   Click image for larger version
ID:	74015   Click image for larger version
ID:	74016   Click image for larger version
The Following User Says Thank You to LATECH For This Useful Post:
Valkyrie5.7 (05-15-2013)
Old 05-14-2013, 05:47 PM
Banned
very nice
Old 05-14-2013, 05:59 PM
LATECH's Avatar
Thank you gearhead. Tons of work. Comment appreciated
Old 05-14-2013, 06:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks sweet- congratulations! Most guys 'cheat' and use the metallic blue on their engine where it wasn't original (and it smells SO GOOD!)- you're a trend breaker!
I need to send you a head stud w/the stand-off for the dipstick...
Old 05-14-2013, 06:14 PM
LATECH's Avatar
Thank you Cobalt. The blue I used is the correct color for a 64. The valve covers arent correct, nor is the timing cover etc. I have all the correct stuff, (covers -intake - carb etc) but wanted to run the later w/pump with 11 bolts.Also a quadrajet was desired, hence the big aluminum intake.
I fabbed a little bracket for the dipstick tube. The reason being is the upper tube is for an A/C car of newer vintage.
Not a original appearing 64 but it runs like it had wheaties for breakfast.
I have a couple of engines worth of covers and brackets,pulleys bolts etc.
I also have another engine complete and a very good virgin 400 block. I am hoarding LOL
Old 05-14-2013, 06:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
And so it is... I had thought the metallic was used on all the 389s but I see where that blue began in '66- my mistake.
Good to hoard now- it seems like yesterday that I could go to any JY and buy a few Q-jets, 4-pin HEIs were a dime a dozen and F-bodies were everywhere for a few hundred dollars. *Sigh*
Old 05-15-2013, 07:58 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Looking good. Any videos so we can hear her purr?
Old 05-16-2013, 06:00 PM
LATECH's Avatar
Naw no video. I am lucky I remembered the camera for the pics you saw . LOL.
Old 05-16-2013, 07:56 PM
Wiki Edits: 15
Hahaha for sure, I understand that. I forget about my camera often.
64 Pontiac 389 to 65' Pontiac 389 environspec Engine 4 02-17-2013 09:07 AM
pontiac 389 ted200008 Engine 14 03-20-2011 01:13 AM
389 pontiac baadgoat65 Engine 3 06-09-2008 10:43 AM
Pontiac 389 with HEI kreuzn1 Engine 2 03-29-2007 06:27 AM
63 pontiac 389 1967bird Introduce Yourself 1 11-22-2004 06:53 PM
