389 Standard Steering to Power Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2012, 08:55 PM
I am rebuilding a 389 and want to convert from standard steering to power steering. What kind of brackets etc. do I need? If you have done a conversion like this, I would appreciate your in put.
Thanks
Old 08-26-2012, 09:28 PM
68NovaSS's Avatar
Wiki Edits: 9
I assume by 389 you have a Pontiac? You need to tell us the year, model, etc. For the most part you will need the power steering pump, steering box and brackets, depending on the car. Take a look at ZOOPS for tons or bracket options.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 08-27-2012, 07:50 AM
RWENUTS's Avatar
More importantly, what car?
You might have fun finding a steering box!!
Old 08-27-2012, 09:11 PM
I have a 1964 GTO that I am doing a frame off restoration on. i live in Canada and we haven't got pontia motors here. Our Pontiacs came with Chev motors. I'm putting a 1965 389 four barrell back in it and want to change the standard steering to power steering. I have the pump etc. but it's the bracketry that has me puzzled. What year and make of brackets do I use - I have lots of different ones. Also, where can I buy these brackets? If someone has already done this - why reinvent the wheel.
Thanks
Old 08-28-2012, 05:48 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Brackets for the 64 GTO are one year only. The 65 is just a tad different.
I put PS on my 64 (in my Pic)
I got my brackets off of E bay and it pays to look at them well before buying. Some guys who sell them , may not know if they are listing them correctly...year model etc...
there is one right now on E bay , not saying you should buy it, just saying so you can use it for reference.
The seller is lilgto447 ad he is a very reputable seller. I bought my 64 PS brackets from him as well. So I can vouch for him.
Just go to E bay and type in -1964 pontiac power steering-
It will bring up a lot of results that you can use as a reference, or buy if you wish . I like pictures, it helps a lot.
One thing I want to mention, I had to change the rag joint also, the standard box has a smaller input shaft than the box I got for mine, so keep that in mind. LA
Oh the pittman arm is different from a standard box, but the pittman arm for the PS box will fit at the drag link end of your existing setup.
Fact is stranger than Fiction
Old 08-29-2012, 10:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another option...
Thanks
I don't know how important originality is to you, but if it's not high on your list of priorities you can use a complete late '69-up 11 bolt water pump set up including the timing chain cover, bracketry, pulleys, etc. to convert it to the later style set-up. Best to find a donor vehicle (craigslist, etc.) that all the parts can be salvaged from so a match is assured.
You can also use the larger diameter damper that was part of the 11 bolt w/p set-up.
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
converting standard to tilt steering wayne gillis Suspension - Brakes - Steering 27 02-19-2012 11:18 AM
manual steering or power steering pat63chevy Suspension - Brakes - Steering 5 02-03-2007 04:40 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
