3899621 bellhousing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2012, 07:51 PM
3899621 bellhousing
Need Help!!!Can I run a 10.5 clutch w a "621" bellhousing??I already have a new clutch set and lightweight flywheel (153) tooth...The transmission is a muncie 4 speed...many thanks
Old 09-03-2012, 05:21 PM
Wiki Edits: 85
I don't know which size clutch came with that bell.
However, the size of the clutch really does not matter as long as 1) it fits your flywheel, 2) it fits your transmission, and 3) there is clearance for it inside the bell.
What really matters is whether the flywheel fits the bell and whether the clutch arm parts fit both the bell and the clutch assembly.
Old 09-03-2012, 05:28 PM
big gear head's Avatar
High Performance Rear Ends
The 621 bellhousing is the one that was used in the high performance Chevy cars, like the Z28, SS Chevelle, SS Camaros and others with the 11 inch clutch. This is a sought after bellhousing to restorers and should work just fine with your clutch.
Old 09-03-2012, 09:05 PM
RWENUTS's Avatar
It'll even take a 12" clutch. I used one in my 70 SS chevelle.
621 bellhousing
Bellhousing for GM T-5 ? Choptop26 Transmission - Rearend 13 07-06-2011 04:56 PM
GM Bellhousing ID zipfactor General Rodding Tech 5 08-02-2009 06:39 PM
GM bellhousing gbpack Transmission - Rearend 3 01-04-2008 06:38 AM
C-6 Bellhousing FourSpeed460 Transmission - Rearend 6 01-22-2006 07:30 PM
Need help on bellhousing raidmagic Transmission - Rearend 13 12-21-2004 10:33 PM
