39 chevy core support - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2011, 08:52 AM
have a 1939 chevy frame with Fatman Mustang II IFS on it. Ineed to locate exactly where the radiator core support is supposed to sit. I called Fatman and they couldn't tell me even though they sold it to me. Help!
Old 01-28-2011, 06:26 AM
Wiki Edits: 27
opps
It's best to build a birdcage fixture out of light tubing, or conduit that bolts to fixed points on the fire wall and to fixed locations on the radiator support before cutting off the frame > if you can find another car that is together take a lot of measurements use level. etc. then set it up. 50 years ago in my auto body class my brother and I rebuilt a front end crash, then brought in a new hood. the instructor said if it would fit with out having to move fenders and things around we would get an A . We had measured a good car and the hood fit perfectly.
Old 01-28-2011, 06:47 AM
Thanks for the help. Here is the big problem, the body is on saw horses, the factory core support was already removed when I bought the car. The Fatman kit has a replacement core support that you must locate and weld in. When I called them they couldn't tell me where to locate their own product. The birdcage idea is spot on if I can get the core support centerline dimension. If this wasn't so crucial I would SWAG it. I appreciate your help.
Old 01-28-2011, 08:57 AM
1971BB427's Avatar
Sometimes we just have to bite the bullet and do it the hard way; put the body on the frame and situate it where it sits corectly and make the measurements. It's a pain, but necessary evil.
Can't tell you how many times I've had to put things together multiple times just to ensure I got the fit where I wanted it. Always a little frustrating until it's together the last time!
Old 01-29-2011, 06:14 AM
As stated above, you will need to have the body back on the frame. Then its fairly easy. Mount the inner fenders to the cowl- you will need to cut them out to clear the a-arms. This will give you the reference point you need since the radiator shell support attaches to the inner fenders.
Old 01-29-2011, 08:33 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
these guys might be able to help you
http://www.chevsofthe40s.com/
Old 01-31-2011, 10:02 PM
spanky36's Avatar
Spanky`s Fix It Shop
Retsfc7, are you talking about the support that mounts to the frame?
Old 02-01-2011, 05:26 PM
Yes, like the one in the picture.
It looks like yours bolts to exhisting frame holes. Mine is welded to the bottom of the frame. The diminsion I need is from the longest point on the front of the frame to the centerline of the support. Yours may be 4" wide, and mine may be 3" wide and a totally different style but, if I have the measurement to centerline of the support I can square it to the frame and get it welded in ... without setting the body back on. Hope this makes sense, thanks for the help.
Old 02-02-2011, 02:55 PM
spanky36's Avatar
Retsfc7, that measurement is 7 7/16 " . I would get it located tack weld it, then when you get the body back on and everything checks out then weld it in. Spanky
Old 02-03-2011, 05:01 AM
Huge help ... good advise, thanks a lot.
core support stu_yoakam Body - Exterior 1 09-24-2008 09:03 PM
seal - radiator to core support? Mad_Max Engine 1 05-02-2008 04:07 PM
Core Support FannyFarmer04 Body - Exterior 0 08-18-2005 08:58 PM
core support 79 camaro 454 Body - Exterior 0 01-04-2004 03:58 PM
subframe core support purkey General Rodding Tech 0 06-30-2003 05:40 PM
