39 Chevy stock suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2013, 10:20 PM
spanky36's Avatar
Spanky`s Fix It Shop
I have a 39 chevy and had a 39 parts car, both were 2 door sedans. They both had a knee action type suspension. Over the years I've seen many rodders starting out on 39 projects and they all had this type front end. Today I seen a bone stock 39 4 door sedan and it had a I-beam with leaf spring front suspension. Anyone seen one like that before ?
Old 05-09-2013, 08:57 AM
Wiki Edits: 27
Knee action
WE have a 36 pontiac in the shop and it has Knee action , and it came with extra front and rear suspensions, .. according to my older brother, the knee action rode smooth, but only lasted a few thousand miles on rough washboard roads before needing a rebuild. But there is a lot of mass to move when turning, you have to move the springs, shocks, etc. when turning. I beams were optional.. there are some small differences in the I beam frames, and most Mustang II kits require a little rework to fit.
Old 05-09-2013, 08:59 AM
RWENUTS's Avatar
I found this thread on the HAMB. Seems the leafs came on the Standard body while the Master got the knee action.
'38 or '39 Chevy Master - THE H.A.M.B.
Old 05-09-2013, 03:07 PM
spanky36's Avatar
Thanks for the HAMB thread lots of info. I had seen these on 37-38 but not on 39s.
Old 07-04-2013, 12:04 AM
Last journal entry: Old guy's low cost Chev coup.
39 coupe (JA body) I'm building had knee-action front. I got a I-beam from 39 business coupe (JB body). I like the I-beam cause I changed over to R&P steering and mounted the steering cylinder/tierods to axle, thus eliminating any slop or bump-steering.
Old 07-04-2013, 09:15 AM
36 Chevy I-Beam Front End
Jumping in here for some guidance. I have a 36 Chevy Standard Coupe with an I-beam front suspension on parallel leaf springs. Have been debating whether to retain the stock system and add a disc brake set up with a Vega Steering box, etc. or convert it to an independent system with rack and pinion. I have not found a cross member unit for the Standard Coupe to support the IFS system. There is one for the Masters Coupe. Any suggestions??
Thanks
Old 07-04-2013, 11:28 PM
Probably not good guidance, and maybe no help at all, but decision a factor for changing my 39 over to I-beam was placement of steering box w/SBC. To use orig steering shaft and box w/pitman arm would have had to leave driver side ex. manifold off. Wanted power steering too, and V-8, and all the other goodies AND maintain somewhat original appearance.Steering box inside frame rail?, outside frame rail, on roof?, in trunk?, and how many U-joints and shafts/supports to get around that motor? Easy (?) solution was R&p on the I-beam. A little wiggle adjustment (grind apart and reweld) here and there and single shaft from steering shaft to R&P w/different exhaust manifold (center dump) and got nuff room so it wont be binding or hitting anything on rough roads. With R&P on I-beam, tie rods always parallel to ground and in direct line with Steering knuckles. and easy change over to disc brakes on front. I haven't seen anyone with disc conversion for the knee action 39, so don't know if available, and I know absolutely zero (nothing) about the Vega, and don't know how 36 frame and steering different from 39, so probably not too much help here. Today making front shock mounts cause the orig. knee-action front suspension also had the knee-action shocks mounted atop the coil spring towers.
Old 07-05-2013, 11:19 AM
Thanks Fast Eddy. I have an R&P P/S unit that I will lay in there and see where the U-Joints need to go Instead of a Vega Box. I have any original steering column, so thats a semi negotiable item in regards to length thru the fire wall. I presume your shock mounts will be steel plates fastened below the springs using longer U-Bolts that hold the leafs in. So many options.... I have a SBC with center dump rams horns, so that should help.
what to do with stock suspension? nova74.307 Suspension - Brakes - Steering 6 12-29-2008 12:11 PM
wHAT SIZE TIRE AND WHEEL WILL FIT UNDER THE REAR OF MY STOCK SUSPENSION 55 CHEVY SEDA POP BOND Suspension - Brakes - Steering 1 02-25-2007 10:56 AM
need advice/ tips on installing air bags in a 1952 chevy coupe with stock suspension Kuztmchev52 Suspension - Brakes - Steering 7 03-07-2006 12:52 PM
stock mustang II suspension montecarloman Suspension - Brakes - Steering 1 03-26-2005 08:39 PM
Need help installing the right size Air bag on 1952 chevy coupe stock suspension. Kuztmchev52 Introduce Yourself 1 07-15-2004 12:00 AM
