39 Chevy suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2006, 12:57 PM
39 Chevy suspension
Hi,
I am new to this list and am working on my first project, a 39 Chevy 2-door sedan. The 16-inch wheels and front suspension must go. I need to know what type of front end, or clip, would be best to use. I would appreciate any instruction on how to cut and assemble a new suspension for this project. Thanks, Ron
Old 04-01-2006, 06:51 PM
jalopy45's Avatar
You might want to look at the Mustang II suspension kits for this car, possible manufacturers like Fat Man Fabrications, Heidts are just 2. You can find them in any rod magazine or in the company reviews on this web site
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 04-01-2006, 07:21 PM
39 Chevy suspension
Thanks. I am wondering though if there is something a little less expensive out there, like an S-10 or Nova clip. Do you know if either one of these would work? Ron
Old 04-01-2006, 07:30 PM
jalopy45's Avatar
Rather than cut your frame in half to add a clip, and if you want inexpensive you might want to rebuild the stock suspension. The parts are available at Kanter Auto www.kanter.com. If your not planning a high horsepower car this would be the cheapest way to go. Adding a clip can be messed up real quick if measurements aren't exact and cause the car to not track straight and the welds need to be top quality, so it probably wouldn't be any cheaper.
Old 04-01-2006, 09:03 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Another consideration is the expense associated with rebuilding the suspension on the clip. Price out bushings, ball joints, and springs to get an idea. Also you may need rotors and calipers. By the time you get done it may well be cheaper (and definately easier) to use a MII based suspension.
Old 04-01-2006, 09:27 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
39 Chevy suspension
RBS has a bolt in kit using MII suspension for your car. You can buy it complete with everything needed or just the crossmember and use your own MII suspension components:
http://www.rbsauto.com/product.asp?P...4&l1=17224&l2=
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-02-2006, 02:34 PM
39 chevy suspension
hi thanks so much for the information. i am looking into all the ideas that were posted. it will take a while to make up my mind on what approch to take. the reason that i ask about a front clip or s-10 frame was that i intend to only make a rat rod type driver,so the suspension does not need to be new. i also lie to build and try new things. this may include trying to instll a clip. however the number one thing for me is to have something safe when it is finished. i don't know what my skill level is in regaurd to a task such as this , but i know that everyone has to try anything at least once to know if they can do it. all this said, you guys do have me seriously looking into a mustang ll suspension. thanks again ron
Old 04-02-2006, 02:39 PM
39 chevy suspension
hi thanks so much for the information. i am looking into all the ideas that were posted. it will take a while to make up my mind on what approach to take. the reason that i ask about a front clip or s-10 frame was that i intend to only make a rat rod type driver,so the suspension does not need to be new. i also like to build and try new things. this may include trying to install a clip. however the number one thing for me is to have something safe when it is finished. i don't know what my skill level is in regard to a task such as this , but i know that everyone has to try anything at least once to know if they can do it. all this said, you guys do have me seriously looking into a mustang ll suspension. thanks again Ron
Old 07-24-2006, 05:37 PM
39 Chevy Front Suspension
I just saw your post today and would like to give you my 2 cents. I put a MII suspension from Chassi Engineering in my 39 recently and have been very pleased. The engineering was great, the people were very helpful and it went in without any trouble. I had not installed one by myself before so I was not very confident. Plan well, measure everything and take your time.
Mike
Old 07-25-2006, 06:33 AM
project 39
Thanks Mike, that what I ended up doing too. Have you worked on the steering yet? I am working on that now and will need to find some part. Any hints on this matter? Thanks, Ron
Old 07-25-2006, 07:20 PM
39 Chevy
Ron,
I had the car running for a short time but 2 weeks before the Goodguys Nationals, my radiator went out and I had to get a new one. I have power steering in it and I'm using a GM power steering pump but it is very sensitive. I have put in a valve that is suppose to slow the steering down but it is still too sensitive. I added two more shims and hope that it will reduce the sensitivity of it but I won't know until I drive it again. A few people on this site do not have power steering in their's and they said it worked out well for them. If I had it to do over again I think I would not install power steering. I had thought about converting it back but didn't have a rack, just paid for a radiator and wanted to go to the Nationals in Louisville next week. I 'm waiting for the lower radiator hose now but should have the car running in a day or two. If anyone knows which radiator hose will work with a small block Chevy and a Walker radiator I would appreciate the info.
Old 07-27-2006, 10:53 AM
Michaelbc, check your camber, castor and toe. If your settings are not right it can cause the steering to feel twitchy. Pay particular attention to camber. Check tire pressure. Overinflation can do weird things too.
57 Chevy Front Suspension Silvern Suspension - Brakes - Steering 6 07-07-2011 09:21 PM
'39 chevy headlight conversion? RodFather General Rodding Tech 4 07-07-2005 01:50 PM
Found a '39 Chevy 2dr 4 sale Bluepen Hotrodders' Lounge 1 09-10-2004 08:49 PM
1947 Chevy Aerosedan 4-Link Rear Suspension Kit??? djjc76 Suspension - Brakes - Steering 3 09-10-2004 03:06 PM
86 comaro front suspension " in 39 olds coupe" Hal Bemis Suspension - Brakes - Steering 10 01-18-2003 06:48 PM
