39 Chevy truck frame woes
Hi... I am new here, and trying to get my truck road ready. My 39 pickup has rust issues, more or less like eveyone does. The frame rust is what has me the most concerned. I don't know where to start, other than I have no confidence in the old rusted frame, nor its design to handle @ 450 horsepower 350. This truck was originally made to run errands like trips to the feed store for maybe a few hundred pounds of cracked corn, not being twisted and abused with massive twisting torque. My initial plan was to rat rod this beast, however the safety issues of a weak frame concern me greatly. Being as there is no bed yet, cab is rusted across the bottom everywhere, making a custom fit bed with newer, safer, and superior technology seems the right move. There are no fendersSo, I am doing research now to see what I can do to fabricate a frame. I have a 78 vette rear end I would like to use, and 03 vette front suspension consisting of the aluminum upper and lower control arms, power rack & pinion steering.
I would like to hear ideas and input from anyone who has thoughts, or experience with similar issues. Thanks, Mike |
Depending on your finances, you can buy a pre-built frame that will allow all your suspension pieces to simply bolt on. Progressive Automotive comes to mind, I'm sure there are others...
| The Following User Says Thank You to stea For This Useful Post: | ||
zmaxmotorsports (02-28-2013) | ||
With the vette components you want to add you already have a ton of fabrication to do so why not get some 2x4 tubing and build your own from scratch. It would probably be no more work than boxing your existing frome and modifying it for the new suspension, plus you're working with all new material.
| The Following User Says Thank You to 39Hemi For This Useful Post: | ||
Mike McFail (03-01-2013) | ||
Thanks...new steel, more confidence. Son is an excellent welder, and can tig it together for me. Thanks again for yur brain waves..
| 1950 truck frame swap to 1980's chevy frame | 1950truck | Suspension - Brakes - Steering | 25 | 01-24-2013 06:13 PM |
| 56 chevy truck frame | Heavychevy56 | Suspension - Brakes - Steering | 3 | 11-10-2010 02:46 PM |
| 59 Chevy pickup frame woes! | Li'l Pine | Suspension - Brakes - Steering | 33 | 07-08-2009 08:24 PM |
| Subing Nova frame into a 1957 chevy truck frame | crshields90 | Suspension - Brakes - Steering | 1 | 02-02-2008 09:15 PM |
| 1996 chevy truck transmission woes | rogerfrts | Transmission - Rearend | 1 | 09-29-2007 10:14 AM |
