'39 Lincoln Zepher Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2005, 09:47 PM
Last journal entry: Some progress
I need a little help on the rear mount. The box I have was used with a closed drive line. I'm putting it in a '48 F-1 PU that has an open drive line that I want to continue to use. The F-1 had a 4 speed with an output shaft that measures 1.31" with 6 splines. The Lincoln has a 6 spline shaft but it is 1.91 inches. The bolt pattern for the mount is also smaller (3.6750") on the Lincoln vs 4.25" on the ford. The both have an 8" bolt pattern for mounting to the cross-member.
Any help would be appreciated,
Jim
Old 09-23-2005, 12:14 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Not sure what your question is. Are you asking for a recommendation for an open driveline yoke that will fit the tranny? Also, I am not sure what the 3.6750", 4.25" , and 8" bolt patterns refer to. Can you send pictures or describe them in more detail?
Old 09-23-2005, 06:40 PM
Lincoln
First of all, Thanks for reading and replying to my problem,
The Main shaft is the one that comes out of the back of the transmission and I always called it the output shaft. I looked up my 1956 copy of Hot Rod magazine that had an article on Lincoln transmissions to check on the correct name for the shaft.
On the back of the case is the rear engine mount that bolts onto the case with 6, 5/16 or 3/8 bolts. The spacing across the transmission is 3.67" from center to center of the holes. This mount is for a closed drive line. The 4.25" is the spacing for the 6 bolts that hold the rear mount on the Ford 4 speed transmission. This mount is for an open drive line. At first glance they looked like they the same except that one was for an open drive line and the other was for a closed drive line. but when I took the mount off of the 4 speed and tried to put it on the Lincoln, it wouldn't fit. The 8" refers to the spacing of the holes for the bolts to attach the mount to the cross member.
My Pickup came with a 4 speed transmission. It had a flathead 6 cylinder engine. The main shaft on the original transmission is 6 spline and it measures 1.31" in diameter, whereas the Lincoln is 6 spline but measures 1.19" in diameter. ... I looked at the original message and there is a mistake in the numbers. Should have been 1.19" and not 1.91". Sorry about that! I didn't check the shaft sizes either, until the other problems developed.
A friend of mine gave me a yoke that fits and will also take the speedometer drive gear so now what I need is the rear mount that is for an open drive line that has 6 holes that are 3.67" from center to center measured across at the widest point. How'ed I do this time?
Thanks again for any light you might shine,
Jim
Old 09-23-2005, 08:05 PM
Wiki Edits: 21
Mucho mejor! How about using the mount that fits the tranny and drilling the frame member to fit?
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 10:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 08:43 AM
38, 39 ford pickup petezr Hotrodders' Lounge 5 09-15-2003 09:45 AM
Transmission for 1949 Lincoln WardellW Hotrodders' Lounge 0 03-04-2002 08:22 AM
