39 olds rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 10:59 PM
it looks like a 4 bar will this work for this hot rod or should i put leaf springs in it am trying to find new bushings an rubbers for it but no luck
Old 03-23-2013, 08:01 AM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Did you post pictures??? I don't see any. I've got a 39 Chevy that I'm putting triangulated 4 link with air ride on. You can PM me if you want and I'll help however I can. I've had a post on here Questions re: 39 chevy or GM
re: 4 link and air ride, but no responses so ------
Pat
Old 03-23-2013, 09:03 AM
Wiki Edits: 27
olds suspension
My son's 36 has parallel leaf springs, late 40's early 50's Olds and probably your 39 uses the 2 parallel arms and coil springs. that is the same design sometimes called truck arm. Gm used it on pickups in the 60's and NASCAR uses on the rears in current cars . If you need to replace the bushings you might have trouble finding parts . It's an OK design, on some of the olds we used to put washers under the bolt heads to be able to get more compression on the rubber bushings on the arms to firm up the ride. usually they have a rear sway bar and panard bar. one disadvantage is they used the lever arm shocks. and rebuilds are expensive. you could switch to regular tubes, look at gm pickups in the 60's for ideas for mounts , I think they used tube shocks.
Old 03-23-2013, 09:12 AM
Wiki Edits: 27
kanter
Contact Kanter auto products, they have Lever Shocks and a lot of old car suspension parts. I got parts from them for the 36 pontiac.
Old 03-23-2013, 06:37 PM
Built a 39 Olds street rod for a customer,a couple years ago,I used a TCI leaf spring kit,sat real nice,and road nice also,was very easy to install,if you use your stock springs and change the rear,the eye bolt is NOT centered under the housing on the early GM cars.
Old 03-23-2013, 07:11 PM
Wiki Edits: 27
google time
Google 1939 olds rear suspension
I have olds rear ends in 2 rod projects
Info about swaps on a later axle and keeping most olds pieces and this info
looks like I bought them from Steele Rubber.
I have
25-0080-32 rear axle track bar bushing and
25-0082-32 rear axle support arm bushing on this receipt
also someone said they used the mid 60's truck bushings.
Old 03-24-2013, 10:58 AM
This olds has a arms on the rear like a buick
'57 Olds front suspension Charlyg Suspension - Brakes - Steering 2 01-19-2013 06:25 AM
40 olds c4 suspension rockenrandy Suspension - Brakes - Steering 2 06-19-2012 09:12 PM
40 Olds rear suspension/ track link ScoTFrenzel Suspension - Brakes - Steering 2 01-06-2009 09:22 AM
corvette suspension into 53 olds should i? orjamie Suspension - Brakes - Steering 4 01-22-2007 01:37 PM
new suspension for a 48 olds, will it work 49olds Suspension - Brakes - Steering 8 01-06-2005 05:26 AM
