39 plymouth pickup any got Pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2006, 07:22 AM
Countilaw's Avatar
Cox Custom Cars
I have a new project. Any one have pics of a 39 Plymouth pickup. Any suggestions where I can get some parts. Looks like I will need a piece of chrome the goes down the middle of the grille. Probably could use a grille too, or at least the lower half.
The grille is mostly louvers cut into the metal. The lower half has been pushed in. I could cut that section out and weld in a new or better section and save a lot of frustration trying to straighten it out.
I will post some pic as work progresses. Any help would be appreciated.
Countilaw
Old 07-08-2006, 10:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do a google image search and you may come up with some pics..On the chrome piece sometimes a piece of chrome trim from a late model can be cut down and used if it is somewhere near the profile tha tyou need..tha tis a wrecking yard find..
On the metal work do a search on the site for metal working and you will come up with quite a bit of info on that..You can also go to www.metalmeet.com and those guys are very helpful as far as that piece...
Good luck
Sam
Old 07-08-2006, 11:32 AM
Countilaw's Avatar
Cox Custom Cars
Thanks one more time. Every little bit of information is helpful. I found a lot of pic on web.
Pics of the scoops on my truck. Rubberman2003 Hotrodders' Lounge 13 01-27-2004 07:39 PM
38, 39 ford pickup petezr Hotrodders' Lounge 5 09-15-2003 08:45 AM
39 to 47 Dodge/ Plymouth Pickup truck T5 adaptation Scubalowe Transmission - Rearend 0 11-06-2002 03:44 PM
39 plymouth sedan chop john Body - Exterior 1 10-22-2001 11:51 PM
39 Plymouth Conversion 39 restoration Hotrodders' Lounge 1 10-22-2001 08:35 AM
