39 Pontiac Lower A arm pivot question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 01:39 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
The part that bolts to the frame has threads. Both "A" ends thread to this part. When the A arm goes up and down with the wheel, the wear at these joints happens in these threads. There is grease zert thing etc. It would take lots of big words to discribe this set up. I hope somebody out there has seen this assembly, maybe answer this:
I see more threads sticking out on one side than the other. I think this is part of the caster adjustment, or effects caster. Does it? What difference would 1/8th make one way or the other? Not to worry? Or Freak Out?
Remember! This aint a Chevy, it's a Poncho! I have majorly burned bridges here dudes, got Fat Man lowered spindle supports, bent steering arms... now I need to put it all back together.....somehow.... ;-)
R
PS I hope to include a picture of the old stuff before I yanked it out.
Name:	39 Pontiac Front SuspensionB 003.jpg
Old 06-26-2006, 08:43 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
lower A frame
rwrther, There is a solid shaft that is threaded on both sides, that is bolted to the frame. The A frame is secured to the treaded ends, where they go up and down, they ride on bushings that are greased, (by zerk grease fittings). These bushings do not ride on the treaded part of the shaft, they turn within themselves. That why they are greased.
Unless the bushings are frozen or worn there should be no problem! Hope this makes sense to you, as it think it does to me. I am old and have a small brain that gets smaller every day.
Old 06-29-2006, 03:58 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
lower A frame
I can't swear this is the caster adjustment for this car, but yes, tilting the lower A frame would affect caster. No reason to freak. could be anything. Longer bolt than the other, thicker washer, etc. there are only 2 things to worry about. Is it all tight, but not frozen and how does the car drive? Caster is what makes the handling. Think of a motorcyle front fork. Straight up and down it would have no self centering ability and be a twitchy ride, too much of an angle and it gets too springy and a ridiculous turning. the same principles apply. Any time you modify the front end, or ride height, or wheel offset, or tire sizes, get an alignment. Cheap price to pay for better handling.
newbie question: how to lower my 48' Buick Super Conv. planet-risa Suspension - Brakes - Steering 2 03-31-2006 03:09 PM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
poly lower control arm bushings dusterbd Suspension - Brakes - Steering 2 11-13-2002 03:19 PM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 08:08 PM
