"39 trans open drive?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2007, 01:12 PM
Youngster's Avatar
I have made a deal on a rear end out of a '42 Ford pick up. I have everything I need to convert my '39 tranny to the open drive. The only thing I'm missing is the drive shaft and the slip yolk. Can anyone tell me what my choices are?? Is there another yolk besides the pick up one that will work?
Old 09-07-2007, 04:58 PM
justold's Avatar
two questions first ,are you using 49 to 52 out put shaft and bearing support or something different , if my memory is correct For used torque tube through 1947 . now back to the yoke , if you are using the ford output any ford pass 49 to 56 will work if you are using a spicer truck or 9 inch rear the better choice would ford F1 49 to 56 or chevy pass 55 to 57 because the u joints would be correct . you would only have to cut to length + - ,there also may be some novas or chevells that will work I don"t remember if they were fine or course spline .HOPE THIS HELPS A LITTLE
Old 09-07-2007, 06:54 PM
Youngster's Avatar
re:'39 trans open drive??
I believe the trans to be from a '48, '49 or'50 F1. At least that's what it was laying next to. I bought the trans and bellhousing for $25 because the bellhousing has a piece broken out and the shift lever was torched off. The rear end is out of a low mileage '42 1/2 ton. I believe Ford went to the open drive banjo type rear ends in the pickups in '42 and used this setup until '47. The '48 on up used the spicer type rear end. What I need is the slip yolk to fit the '48 type open drive bearing retainer.
Old 09-07-2007, 07:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
eggs have yolks... the trans and rear diff use yokes.
Old 09-07-2007, 09:05 PM
Youngster's Avatar
I always wondered why the YOKES wheren't white and yellow
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 07:37 PM
drive shaft hits cro77 Transmission - Rearend 8 04-26-2007 06:53 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 09:58 PM
Trans go's into Neut at low rpms brainsboy Transmission - Rearend 3 09-30-2005 09:30 PM
4 wheel drive trans problem el Transmission - Rearend 0 06-25-2003 06:17 PM
