Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 390 Ford engine
Thread: 390 Ford engine
Old 09-05-2012, 07:14 PM
Richiehd's Avatar
Richiehd Richiehd is online now
JS-70
Tell us more Mel there are guys here that can help. What ignition are you running? You pull a couple plugs? Are they wet? if yes that you ar getting fuel. How old is that fuel?
Does it pop, spit, or what when you crank it. Did you try turning distrbuter and see if it kicks back. Coil wired right? Got proper grounds on Motor and frame?
The Following User Says Thank You to Richiehd For This Useful Post:
Mel Smith (09-07-2012)
