Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 390 Ford engine
Thread: 390 Ford engine
Old 09-06-2012, 05:53 PM
Sixtigers Sixtigers is offline
I'm not trying to insult you--I've made this mistake myself in the past. I know you said you have the firing order right:
1) Are you sure you set the static timing with #1 at TDC--the compression stroke?
2) Are you sure you have the firing order going in the right direction on the distributor?
