Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 390 Ford engine
Thread: 390 Ford engine
Old 09-08-2012, 08:14 AM
cdminter59 cdminter59 is offline
390 Ford engine
Originally Posted by Mel Smith View Post
Ok guys just as I was beginning to suspect the distributor was my problem, I replaced the distributor with one that I had laying around and now I;m getting an attempt to start. Not running yet but trying so now I can get a light on the timing and get it set right on and I'm sure it will run. Thanks to all for your input and ideas but the thing that was throwing me off was getting a spark through the inlighn spark tester. I'm fully confident that it will be running when I have an hour or two to devote to it. These old distributors are very touchy and I would like a replacement option for an electronic distributor replacement for this FE.
Check this Pertronix Distributor PerTronix D133711 - PerTronix Flame-Thrower Plug and Play Billet Distributors with Ignitor II Module - Overview - SummitRacing.com. This is a stand alone unit. This is the coil to use with it. PerTronix 45111 - PerTronix Flame-Thrower II Ignition Coils - Overview - SummitRacing.com. They are compatible with multi-spark CD ignition boxes for outstanding versatility. Check this ignition system package. PerTronix COMBOBBFR - PerTronix Complete Ignition System Packages - Overview - SummitRacing.com
