Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 390 Ford engine to Three speed tranny
Old 10-26-2010, 01:24 AM
JeffB's Avatar
JeffB JeffB is offline
Ford FE blocks are one of the easiest to interchange parts with,there would be no advantage to buying a later 390 rather than rebuilding the one you have.If you are not real familar with the FE's you may want to Google:mre books they have some great books that cover the interchanges and engine codes so you know what you have to work with.With very little effort they will produce some real torque so be kind to that 3 speed.
